Old May 10th, 2008, 04:28 PM   #1 (permalink)
New Princeton Reverb Reissue -- first look
I saw and played the Princeton Reverb Reissue today at the New York Guitar Show. Proud poppa Shane Nicholas (Fender vp of marketing) says it'll be in stores in June at $799.
It sounds like 1965 all over again--surprisingly rich bass, better than most PRs I've heard. And that Blackface tone is exactly right, but it gets that great Princeton edge and fairly reasonable volume. The reverb is rich and full, and can be moderated from a pleasant echo to full surf. The tank is in a bag. The lowest speed on the tremolo is slower than I remember, which is a good thing, and it has that great bias-trem sound.
THIS IS NO BEDROOM AMP. It's loud, although like other 15 watt amps, it will likely be marginal with a loud drummer.
It's built just like the DRRI and the TRRI, on a circuit board. I think that's the right way to go... maybe a little inconvenient for us modders, but it ensures consistency from amp to amp. Yes, sure, some owners will tear out the circuit board and install an eyelet board, and they'll rave about how much better the tone is. But for 99 percent of people who have been yearning for a real live blackface Princeton Reverb, this is the real deal.
The speaker is a Jensen C10R*, and I was pleasantly surprised at how good it sounded it the PR cab. The baffle is removable, and there's room for a 12-inch speaker if you're so inclined.
* corrected speaker type
Billm is offline   Reply With Quote
Old May 10th, 2008, 04:38 PM   #2 (permalink)
alexpigment's Avatar
seriously?? $799 MSRP or street price?
alexpigment is offline   Reply With Quote
Old May 10th, 2008, 04:59 PM   #3 (permalink)
God, I just found where most of my check from Uncle Sam is going.
Flannel Pat is offline   Reply With Quote
Old May 10th, 2008, 05:00 PM   #4 (permalink)
$799 is the street price. So $150 below the street price of the DRRI. Seems reasonable to me.
Old May 10th, 2008, 05:10 PM   #5 (permalink)
Stuco's Avatar
I hope this doesn't jack up the price of the SF princetons.
-"You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do" J. Garcia
Stuco is offline   Reply With Quote
Old May 10th, 2008, 05:26 PM   #6 (permalink)
BrianF's Avatar
now that this will be available ...why would one pick this amp over the Deluxe Reverb 1x12?
Old May 10th, 2008, 05:30 PM   #7 (permalink)
Scott S's Avatar
That's good news, Bill. If I get a chance, I'll try one out.
- Scott
Old May 10th, 2008, 07:43 PM   #8 (permalink)
maestrovert's Avatar
it'd be a bit smaller/lighter without losing anything tonally speaking, would be my guess.....
Sing the Song Bro'
Play on Drummer
www.godonthe.net
Old May 10th, 2008, 07:48 PM   #9 (permalink)
Less headroom (probably), and the 10" isn't inferior to the 12"... it's just different.
micpoc is offline   Reply With Quote
Old May 10th, 2008, 08:40 PM   #10 (permalink)
gpower's Avatar
I can't wait to put one through it's paces. If it holds true to the vintage Princetons, tonewise, it should sound gorgeous.
Whether you think you can...or you can't...you're right!
gpower is offline   Reply With Quote
Old May 10th, 2008, 10:18 PM   #11 (permalink)
mellecaster's Avatar
It's all about the Tremolo circuit on those (at least on the Originals)
Old May 11th, 2008, 12:20 AM   #12 (permalink)
bradpdx's Avatar
Same reason you might have in 1965 - the Deluxe is a bit louder, a bit bigger, a bit more amp. The differences aren't as earth-shattering as going from a Champ to a Twin, but very real.
The Princeton will definitely give you more breakup on the bandstand than the Deluxe, all else being equal. Conversely, the Deluxe will give you more headroom. Not much in either case, but that's why the difference is only $150.
String bender ordinare!
Old May 11th, 2008, 12:27 AM   #13 (permalink)
BrianF's Avatar
Interesting.. I have a SF Princeton Reverb and without mods it is weak and boxy sounding compared to a 1x12 or 2x10. My observation is that people tend to want to mod amps to make them something they are not...namely make them sound bigger. The PR falls into that category... especially for gigging. I think there's a reason Fender discontinued the PR...lets see how long this one sticks around.
Old May 11th, 2008, 12:39 AM   #14 (permalink)
Big Mike Simpson's Avatar
Interesting... I have a SF Princeton with a 12" speaker that sounds GREAT!
Big Mike
http://www.myspace.com/bigmikesimpson
Big Mike Simpson is online now   Reply With Quote
Old May 11th, 2008, 12:49 AM   #15 (permalink)
BrianF's Avatar
See? you modded it! Any other mods?
Old May 11th, 2008, 06:25 AM   #16 (permalink)
68 here. Didn't sound boxy, but the Oxford couldn't handle the bass.
Threw in a 10" Weber California, and ta-da--big sound, small package.
Differences between a DR and a PR are not that big, but the PR's more primitive PI, and bias varying Tremelo do make them sound different. The DR sounds thinner at lower volumes, but breaks up more smoothly when you crank it. The PR sounds richer clean, mild OD is great--that point where you're "on the edge"--but full on crankosphere can get pretty ratty.
Different amps, different feels, different sounds.
Are they too close to have one of each? Probably.
Both are considered very high up in the Fender food chain, because they are both great, and I mean GREAT amplifiers.
Give me a Gibson or Fender guitar, ten feet or so of wire and a DR or PR, and I am a happy camper.
P.
Listen to your mother
Paul G. is offline   Reply With Quote
Old May 11th, 2008, 06:49 AM   #17 (permalink)
Capel's Avatar
I've played it - can't wait to get one.. it the goods!!
Capel is offline   Reply With Quote
Old May 11th, 2008, 06:02 PM   #18 (permalink)
bluesfordan's Avatar
where did you get to play it?
bluesfordan is offline   Reply With Quote
Old May 11th, 2008, 06:23 PM   #19 (permalink)
Capel's Avatar
Fender Australia had one for their dealer seminar last weekend.... when I get my act together I'll post up pictures of the custom shop fenders & gretches.
Old May 11th, 2008, 06:24 PM   #20 (permalink)
I'll take a guess and say that he was at the NY/NJ Amp Show. That was its first public appearance.
Old May 11th, 2008, 07:01 PM   #21 (permalink)
outbreak's Avatar
capel do you by any chance know the rough australian rrp? been thinking of a blues jnr lately but one of these would be ALOT nicer
'07 MIM std tele
'07 Epiphone Studio Dot
'08 Gretsch 5120
'08 Ibanex accoustic
'07 VOX ad50vt
outbreak is offline   Reply With Quote
Old May 11th, 2008, 07:11 PM   #22 (permalink)
VWAmTele's Avatar
Bill - are you able to compare this with the Princeton Recording amp? Thx.
VWAmTele is offline   Reply With Quote
Old May 11th, 2008, 07:24 PM   #23 (permalink)
Dacious's Avatar
I have a SF Princeton Reverb I put a bias pot in and changed to a 240 Volt primary tranny and almost nothing else. I use a Vibrolux Reverb for my big gig amp, but the PR is a great lower-volume unit and lives with our drummer. Same reverb pan, even better tremolo.
The only changes I have planned are to do a cap job, as it's futzing out on low notes to easiliy, and maybe going to some Radiotron NOS tubes I have.
Even with the stock 10" eminence speaker (I presume it's stock - 1980 date matches other components in the amp, Silverface costmetics) it sounds just fine.
Old May 11th, 2008, 08:20 PM   #24 (permalink)
mistermullens's Avatar
This is great news! I've been looking for a new amp for a long time and I'm hoping this will be the one. I've been looking so long that I've been considering upping my budget on this amp quest. I can wait another month or so now. Thanks!!!
When the power of love overcomes the love of power, the world will know peace. - Jimi Hendrix
Old May 12th, 2008, 01:37 AM   #25 (permalink)
Brian,
The previous owner had put in a peavey black widow for more hearoom and I took it out and put in a Fender labeled Eminence. I paid $150 for the amp and sold the BW for $68 then bought a used speaker for $20... Just about every time I take it to a jam someone remarks on how good it sounds. No, no other mods as far as I can tell. I'm the 2nd owner and I don't think it has had anything done to it since it was new, the tubes are old RCA's.
Big Mike
Old May 12th, 2008, 01:37 PM
