deluxe amp
Anyone here use an eminence speaker in a tweed deluxe? I was told they breakup a bit quicker than the jensen ri. I had one in a 53 wide panal and liked it. This time im getting a 5e3. Dave
www.myspace.com/65sunburst Last edited by blues : May 9th, 2008 at 09:57 AM. |
I've got an Eminence/Fender 12" speaker that came out of a Hot Rod Deluxe. It's a 50w ceramic. I've tried an Eminence alnico that's now discontiued and also a Weber 12A125O and a Celestion G12H30. The HRD speaker is considered to be a crappy speaker but I like it in my Clark 5E3. Tha alnicos break up to soon and aren't tight enough sounding in the low registers and the Celestion had too much low end and not enough highs. The HRD Emi/fender is the most balanced sounding too me. I gig with the amp so it's volumes are 10 Normal and 12 Bright and the tone is adjusted from 5 to 7 depending. The best thing is you can find those speakers cheap because most guy's hate em. I guess a lot of it depends on your skill as a player.
Hi blues,
when you want earlier breakup you can also try different tubes. At the moment I use a JJ ECC 83 in the first tube-position of my 5E3 clone (with Jensen RI P12Q) and it breaks up easily with a Tele. Klaus |
Thanks guys im going to try out an eminence. I can always experiment later.
www.myspace.com/65sunburst |
