Old May 4th, 2008, 05:25 PM   #1 (permalink)
Did Fender Originally Laquer Tweed Cabs?
Wondering if the original tweed cabinets came from the factory coated or bare??
I built a tweed champ clone. I kind of like the uncoated natural look.
Thanks,
Mark
IowaTele is offline   Reply With Quote
Old May 4th, 2008, 07:01 PM   #2 (permalink)
Dacious's Avatar
If they weren't lacquered, they may have been shellacced. It would be good to do some sort of coating, otherwise greasy marks like fingerprints or dirt, even mildew or fungal bloom will build up on the surface of the cloth, or you could get 'bleed' of the contact adhesive through it. Even a clear coat of satin poly that sealed the weave would work, without producing too much change in the appearance.
Old May 4th, 2008, 07:25 PM   #3 (permalink)
Minwax honey pine polyurethane does pretty well, just a slight tint. Tweo or three coats and you have something you can wipe clean.
Ricky D. is offline   Reply With Quote
Old May 5th, 2008, 07:54 AM   #4 (permalink)
GUITARmole's Avatar
They were lacquered.
GUITARmole is offline   Reply With Quote
Old May 5th, 2008, 09:11 AM   #5 (permalink)
BrianF's Avatar
They were lacquered....Fender was efficient and frugal...if they used lacquer for the guitars they used the same stuff on the amps too.
Old May 5th, 2008, 06:08 PM   #6 (permalink)
Scott S's Avatar
FWIW, I'm planning on letting my 5E7 accumulate some wear-and-tear before I apply any finish to the cabinet. I'm told that they can't "relic" at all once a good coat of MinWax is on them!
- Scott
Old May 6th, 2008, 03:09 AM   #7 (permalink)
It is my understanding that Fender did not lacquer them, but that some folks did that a few years later to keep the "fray" from happening.
Every original tweed I've ever seen appeared to have NO lacquer... but that could be due to the fraying and age making it look that way.
I've been known to be wrong quite often ;)
Old May 6th, 2008, 08:50 AM   #8 (permalink)
Chris Callahan's Avatar
Someone posted somewhere that it was shellac.
I've used Zinser Amber shellac thinned 1:1 with alcohol (three coats sanded in between) on cloth (something like Gramma's drapes, but I'm that kind). I really liked the result.
Chris
Chris Callahan is offline   Reply With Quote
Old May 6th, 2008, 09:35 AM   #9 (permalink)
BrianF's Avatar
It was nitro lacquer for sure. Those old tweed amps that look frayed have it worn off. If you pull off a back panel on an original aor inpect areas that hve not been exposed to light or abuse you can still see it intact. The only shellac use is from modern day builders attempt to recreate the look...although the amber shellac is way too fake and orange looking.
Old May 6th, 2008, 08:58 PM   #10 (permalink)
Orange... bleh... I hear you there.
Somebody, somewhere must have a good way to "age" nitro on tweed...
Old May 6th, 2008, 09:08 PM   #11 (permalink)
bradpdx's Avatar
It was lacquer, the same type as was on the guitars. Cheaper that way, works fine.
String bender ordinare!
Old May 6th, 2008, 09:14 PM   #12 (permalink)
aznrambo481's Avatar
I thought taking guitar to tanning salons was an odd idea, but amps may take it to a whole new level of guitar geekiness.
"Never age. Never die. Live forever in that one last white-hot moment, when the crowd screamed. When every note was a heartbeat. Burn across the sky."-Terry Pratchett, Soul Music.
aznrambo481 is offline   Reply With Quote
Old May 6th, 2008, 11:20 PM   #13 (permalink)
BrianF's Avatar
What guitar finishers do is either age real nitro in a glass jar out in the sun for a long time...or just add a drop or 2 of lacquer tint (yellow or brown) to it. 1 or 2 drops goes a long way to tint nitro.... Then spray the nitro mix with a Preval bottle
Old May 8th, 2008, 07:52 AM   #14 (permalink)
FrankB's Avatar
the secret is out....doh!
yes, the babyfood jar/pickle jar in the window and dated by the way to keep track of which is which... is an old school problem solver in a way.
tinting lacquer is a good idea depending on what the customer is looking for.
the best way to get let's say a neck to look older is to play it with no finish on it for a while, this way you body oil will penetrate the neck where you play it. When you spray it, the "touched" areas will be redder or darker than the untouched areas.
http://www.myspace.com/frankbrigandi
http://www.myspace.com/rotosonic
If less is more, then I am going to give it my all, and do nothing.
FrankB is offline   Reply With Quote
