Be careful what you ask for! (Weber content)
I just replaced the stock Eminence speaker in my DRRI with a Weber 12A150 (50 watt), along with a beam blocker. I'm looking for a little cleaner and tighter definition and response at mid-volume levels. The stock speaker seemed to "lose the note" with increased volume. Ted recommended that I try a higher power alnico.
And, as promised, yeah, I got what I asked for. Just a little too much of it! The bass is rolled off significantly and there's mid and high frequency definition in spades. Downright barky and sparkly. I realize it's going to take a heap of playing to break it in a bit (good thing I'm in a band nowadays). I'm looking forward to having it mellow out just a tad, though. I think the bass rolloff, although it sounds weird to me right now, is going to open up the overall sound when the band it playing and give other instruments a little more room. Anybody else have similar experiences? |
Yep,
I replaced the farty original speaker in my 79 Champ with a very robust Weber 8-inch 8F125. Ted suggested it when I requested a speaker that would maximize clean headroom with little and late breakup. I felt the speaker was a bit dark when first installed, but boy, did it project! It's been over a month now of pretty regular playing at high volume.... it sounds significantly brighter..... to my memory.... It has a great tone and power handling capability..... mates really well with my pedalboard effects. I'm really happy with the speaker. It was a good choice because it is custom built for the vintage 3.2 ohm Champ requirement. |
once it's broken in, i'm betting this story has a happy ending.
Truth is stranger than fact ... www.myspace.com/woodymitchellmusic BAND PAGES: www.myspace.com/stragglerswing (Stragglers - Western Swing) www.myspace.com/loafersgloryband (Loafers Glory - '70s country-rock) |
Yeah that is good speakers to have. It's very lively I know cause I had it in my 12" Pro Reverb and sound very amazing. (Mine had the light dope which is in the 57 Low Power Tweed Twin.)
I agree with Woodman give it time to break in and it start sounding much more amazing.
tazzboy
Perhaps I need to give my Alnico Blue Pup a little more time to break in, then. I bought it for its power-handling capability, but it sounds dark and muffled compared to the speaker I was using before (an ancient 8" alnico speaker with a tiny voice coil that had probably been a light-duty ceiling speaker in a previous life). The BP doesn't sound *bad* per se, but it doesn't have the brightness and chime I was expecting from the descriptions...
- Scott |
Besides the break-in period, the new stiffer speakers require a rethink on how you set your EQ..... sometimes radically different that what you're used to with the original speakers. Because I could run at a much higher volume and still stay clean, I found I could run my bass EQ MUCH HIGHER, but had to turn down my treble eventually.
In my 79 Champ, it seemed I had to run the Bass at 5-6 and the treble around 9 originally. After break-in of the Weber 8F125, it seems the sweet spot is Bass at 10, Treble at 8. The speaker has brightened up, so I feel tweaking down the Treble helps the tone stay fat. When I use the Champ in rehearsal instead of my Princeton, I just max everything and control it from the guitar knobs.... it can cut through the mix pretty well with the extra Treble. |
FWIW, it took ALL my Webers a good 20+ hours of *real* playing to come into their own, at which point i was totally delighted. it's worth the wait!
Yeah Woodman! I feel like my beefy little 8-inch Weber 8F125 is just going to get more and more full sounding as the days wear on.
I love that I can just pick-up the little combo and know that I have enough volume and tone on tap to hang with almost any playing situation outside of an actual gig. In fact, I betcha that in a small gig, the little Weber could get by. |
My Traynor with a ceramic Blue Dog sounded much better from the get go and, got even better again and smoother sounding as I put time on it. I'd say it stabilized after 20 - 30 hours of playing.
Whether you think you can...or you can't...you're right! |
#10 (permalink) | |
Tomorrow afternoon, I'm having an outdoor rehearsal with the boys.... full drum kit and all..... My Princeton Reverb is still at the shop getting a recap and tweaked.... so once again, the mighty Champ is gonna hafta sub-in. I am going to run it with an extension cabinet though.....
Luckily, our drummer is really a considerate guy. We generally play pretty quitely overall. Our bassist has a new 320-watt Eden Nemesis 2x12 combo, so I'm sure he'll want to crank it now and then. Even though I'd rather have the extra power of the Princeton, I am going to consider this as another great opportunity to get some quality break-in time with the new Weber speaker in the Champ. |
#12 (permalink) | |
I have the exact same speaker in my '77 SFDR. It's a real sweetie! I love the clean headroom and tight low end. Humbuckers are no sweat now.
I did one small mod to my amp that made a world of difference with this speaker. I clipped one leg of the "bright cap" on the volume pot to cut the brightness. Then I mounted a small switch on the back panel and ran two wires, (one to the cap leg, the other to the volume pot), so I can switch the bright cap "on" for my humbucker guitars, and "off" for my single coil guitars. Works like a charm with the Weber speaker!
Dogs have the right idea! |
#16 (permalink) |
Another Update
After about 30-40 hours of playing now, the Weber is sounding truly sweet. The low end took a while to develop but it's just at the right level now. And maybe it's my imagination, but my amp seemed to get a lot louder over the break-in period. I used to put the volume up around 4 or 5, now it's staying just over 3. |
