Old April 25th, 2008, 01:19 PM   #1 (permalink)
Trentcaster's Avatar
Difference between a Princeton Reverb and a Princeton?
I was just hunting around on ebay, and noticed that Princeton Reverbs can go fro over $500 while Princetons I can find for under $300. What's the difference between the two?
Trentcaster is offline   Reply With Quote
Old April 25th, 2008, 01:23 PM   #2 (permalink)
Not trying to be a wise guy, but it's the reverb.
They sound pretty much the same, otherwise.
Billm is offline   Reply With Quote
Old April 25th, 2008, 01:30 PM   #3 (permalink)
CancerLeoCam's Avatar
More gain in the PR and the obvious..
"I'm a man who believes that right is right and wrong is wrong. Treat me right, and I will give you my all. Treat me wrong, and I will give you nothing. They don't like me for that, but that's the way I am." - Johnny Paycheck
CancerLeoCam is offline   Reply With Quote
Old April 25th, 2008, 01:53 PM   #4 (permalink)
The Princeton will stay clean pretty much all the way up the dial and it isn't quite as loud. I would say that the Princeton is the same volume when it's dimed as the PR is when it starts to crunch.
Old April 25th, 2008, 02:08 PM   #5 (permalink)
So it's basically separated by gain and reverb? Thanks! Just a quick question...
Old April 25th, 2008, 03:48 PM   #6 (permalink)
bradpdx's Avatar
The gain difference is quite substantial between the reverb/non-reverb Princetons. The PR adds the usual reverb mixing stage which adds more than 10dB of gain.
If you want to play fairly clean, a non-reverb unit will do. For the additional overdrive that many desire, the reverb model is much preferred.
String bender ordinare!
