Old December 13th, 2003, 12:03 PM   #1 (permalink)
Crackling Twin??
When I turn on my twin, after about ten minutes it starts crackling and frying quite loud. Even with the volume off.
If I put it on stand by for however long, when I turn it back on it still lasts (the crackling) for five minutes or so.
Almost every gig, WHY???? :(
I've wiggled every tube, sprayed sockets, . . . :?
Thanx in advance, Anybody?? Redd
Redd Volkaert is offline   Reply With Quote
Old December 13th, 2003, 12:34 PM   #2 (permalink)
idylldon's Avatar
Redd,
Because it seems temperature related (starts when the amp heats up a bit), my first guess would be the preamp tube plate load resistors. Unless I'm not remembering right, I think you've said your Twin is a '65. If so, and if it hasn't had the plate load resistors replaced, that would be the first place I'd look. The originals are 1/2-watt carbon comp, and they take a bit of a beating over time in that application. The common replacements are usually metal film. Some folks who think carbon comps make a tone difference in this area of the circuit usually use 1-watt carbon comps (or films) because they'll remain more stable in the application.
I'd also pull the chassis to check for bad solder joints, though my guess is that this would be far less temperature dependent. I've seen quite a few older Fender circuit boards flex enough to break the solder line around the component lead. You have to look close to see it. Heating and reflowing the joint fixes the problem.
You could pull the phase inverter tube, the small tube right next to the power tubes, which would tell you if the sound is originating in the preamp or power amp section of the amp. If the crackling goes away, then the problem is in the preamp section.
You probably know all this already, but I thought I'd mention it just in case you didn't.
Cheers,
Don
BTW, if you lived in So. Cal I'd fix that amp for you for free. OK, you'd have to show me a few licks! ;-)
idylldon is offline   Reply With Quote
Old December 13th, 2003, 01:16 PM   #3 (permalink)
Cam
Cam's Avatar
See if this page helps....
http://www.hoffmanamps.com/fenderservice6.htm
Relic Schmelic!
Play the darn thing! Wipe it down after and put it in it's case!
Cam is offline   Reply With Quote
Old December 13th, 2003, 04:12 PM   #4 (permalink)
Big Cookie's Avatar
Redd call me
I'll line it out for you.
Big Cookie is offline   Reply With Quote
Old December 14th, 2003, 12:01 AM   #5 (permalink)
Thanx
Thanx so much for the tips, I'll check it out & see.
Old December 15th, 2003, 05:36 AM   #6 (permalink)
Baard's Avatar
Well I had the same problem
with my old super reverb. cracle snap pop zizzle.... I changed all the tubes, and it was gone....
Baard
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident.
Baard is offline   Reply With Quote
Old December 19th, 2003, 04:18 AM   #7 (permalink)
same here
Hi Redd - funny - I have a 65 Twin doing the same damn thing right now....maybe it's the weather...
I used to live in Austin forever (now in Cali)
Go meet Jon Bessent at Walter Hutchins Musical Exchange. He's a very wise Fender amp guy - and a great guy/character. He's the engineer behind Austone pedals (builds for Mr. Gibbons et al.)
Anyhow, Jon knows his **** and you probably know him anyhow - He can tear apart any Fender like it's nobody's biz... Buzz him at 467-9600
I used to check you out occasionally on Sunday at the Continental. Holy cripes. You smoked and twisted it all up. Thanks for those moments~
-Dave in Cali (Ex-Austinite)
dp2me is offline   Reply With Quote
Old December 19th, 2003, 04:26 AM   #8 (permalink)
censored??
now, just when did the word s-h-i-t become a bad word??
-Dave
Old December 19th, 2003, 04:34 AM   #9 (permalink)
p.s
One last comment Redd-
If you haven't been there, Walter Hutchins Musical Exchange is in Hyde Park on North Loop. Jon has a workspace in the shop.
PS - I would recommend Jon to anyone in the area. He did a killer job diagnosing my Twin and rebuilding a silver Princeton R. for me....
