Old April 13th, 2008, 12:43 AM   #1 (permalink)
refin's Avatar
Amp Gurus--Need Tweed Deluxe Help
I think I've posted this before,not sure.
On a couple of my tweed amps (especially the '57 Deluxe),I can turn the volume knob on the guitar (any guitar) and get a scratchy sound through the amp.
Now,it's not the guitar.I read an article before by Gerald Weber which mentioned that certain amp parts have drifted from their values when you get this sound,and no amount of spray in the pots will solve the problem (I can't find the article).
Also,on the Deluxe,I still get sound with the volume pot on zero---it's real bassy,and the true sound doesn't kick in till about 2 1/2.The other volume pot (mic) is also on zero.
Any ideas? The amp was recapped about a year ago.
Thanks in advance!
"For You,Lord,are good,and ready to forgive,and abundant in mercy to all those who call upon You."
Ps. 86:5
http://www.soundclick.com/bands/0/refin_music.htm
MASTER VOLUME? WHAT'S A MASTER VOLUME?
refin is offline   Reply With Quote
Old April 13th, 2008, 01:54 AM   #2 (permalink)
Have you tried swapping out the pre-amp tube?
My white hairs had you fooled, didn't they, son?
Yes, Sir!
Ha! Drive on!!!
Westerly Sunn is offline   Reply With Quote
Old April 13th, 2008, 10:21 AM   #3 (permalink)
refin's Avatar
Yeh,I've swapped tubes.The article I read mentioned some resistors that have drifted from tolerance.
Ps. 86:5
Old April 13th, 2008, 11:18 AM   #4 (permalink)
mr_hankey's Avatar
Thanks in advance!
I had the same problem on my Bassman. The filter cap of the preamp section measured open, and its grounding wire wasn't connected; so it couldn't do its job of preventing the signal from bypassing the tonestack and volume control; and thus being added out of phase to the signal coming off the second triode.
mr_hankey is offline   Reply With Quote
Old April 13th, 2008, 12:32 PM   #5 (permalink)
EMan's Avatar
Typically, this is a result of some DC voltage on the input jack.
Plug a guitar cord into the amp's input jack, and measure the voltage (DC) between the tip and the sleeve on the other end of the guitar cord.
EMan is offline   Reply With Quote
vB code is On
Forums Directory
