#41 (permalink) | |
Peavey stopped making the Classic 100 head several years ago and stopped making the Classic 50 head two years ago. Nevertheless, they can still be found on the used market. If I had as much trouble deciding on speaker compliment, I would just buy the head a cab that you like. You can add the other cab later. Also, Peavey now makes the C30 in head form. |
#44 (permalink) |
I hate they dropped the Classic 50 Head. I thought they looked cool as hell, and were not bad. Didn't like the black, but the tweed heads were the bomb to look at. I still think a Bel Air is a better design, but the Peavey Heads LOOKED good.....
I hate the new Peavey logo thing. Murph. |
#45 (permalink) | |
I'm thinking about making another cab for it to cut it down to a 210 format, so it's easier to tote around, or hopefully trade the DB 115 for a 210 version. I'll also try taking 2 of the power tubes out and plug into the 8 Ohm jack for half power, just to see, although I love the clean headroom as is. I set the Normal channel like this - Master 12, Normal ~ 4, Bass 12, Treble 10, Mids 0, Presence depends on what p/u I'm using, roll it off for tele bridge. Last edited by Little Ricky : June 25th, 2008 at 03:09 PM. Reason: typo |
#46 (permalink) | |
I'd love to find a Blues Classic, though. That's a Classic 50 with a 15" speaker. Those are pretty hard to find, though, and Peavey discontinued them a long time ago. Really, the only way to be sure is to go out and compare them for yourself. I know that's not always possible, but that's really the only way. As for the weight issue, Peavey sells a set of pop in casters that wouldn't be too hard to put in. |
#48 (permalink) |
I been playing a C50 4/10 for years and only had it retubed once.The blue marvel speakers in it are good but like all 10" speakers,they're like a beam of light,they don't sound too loud from 3 foot to the side but will nail their head to the wall from across the room.
These amps are cathode biased and you can't pull 2 tubes out without overloading the other tubes. |
#49 (permalink) | |
You can't pull two tubes on a Classic 30 because the tubes are wired in series. You can make up some dummy tubes by snipping off some of the pins on two tubes, though. |
#50 (permalink) | |
#53 (permalink) |
Well, that should work but make sure the other end of the cable is taped up. You don't want it grounding at an inappropriate time.
You should be able to pick up just the plug at a music store or Radio Shack. |
#55 (permalink) |
Congrats! Be sure to give us a review once you get a few hours on it!
Those are a couple of sweet Teles, too! And, looks like some sort of adult beverage keeping the amp from flying off... |
#56 (permalink) |
I tried them both extensively and for me I really preferred the 2x12 in this amp. I read some folks making comments about punch with the 4x10's but I didnt find that to be the case with these amps. my fender's yes, but not with this circuit for some reason. The 4x10 are smooth and darker with these amps from my experience and those that were with me at the time.
We all liked the 4x10 good enough, but I tried it first and when the next day I brought in the 2x12 we all just loved it. MY Fender VR withits 2x10's are punchy as hell, but for some reason that doesnt happen with this peavey unless it's changed. I like the brightness of the 2x12 and it gets jangely too, |
#57 (permalink) |
first impressions - its quite a cool monster! gives pretty good tone(s) on low volume as well. Seems that clean channel is juicier than drive, drive sounds however not bad at all, just kinda seems thinner. Reverb not bad , rather vice versa (long tank). Everything seems to work perfectly ( from cooling fan to footswitch, all chickenheads included), except a weird thingy i just noticed :
the R/H side speakers (upper and lower) move much much less than L/H - any directional comments on that? Thereīs 1 more question - the speakers jack - its connected into 16 ohms . Can i put the jack into 8 ohms instead, and what it would change ? tt |
#58 (permalink) |
ive owned the classic 50 and the delta blues loved the delta blues but if you play in a loud band a tiny bit lacking in power so i switched to the classic 50 2 12,s nice amp but i really liked the single 15 ive since bought a trace elliot amp but kept the classic im going to take out the 2 12,s and modify the amp putting back in a killer 15 inch speaker .......
#59 (permalink) |
There are mods to "fatten up" the drive channel, I've done them to my 410, and they do work. PM me your email & I'll send you the list of mods I did.
"I've got callouses, from all those nights, spent playin' a Telecaster, 'till my fingers bled Bud Light" - Travis Tritt |
#60 (permalink) | |
I wouldn't run it off of the 8 Ohm jack since that will present the amp with an impedance mismatch. There is really no benefit to it, and it may make the amp sound bad. I did it with my 5150 and didn't like the results. Plus, it'll definitely wear the tubes out faster and may cause other problems with the amp. If you need some help to see if the speakers are wired right, check out the Peavey Amp Forum. You can get there from this link: http://www.peavey.com/support/forums/ You will need to register, but it's a valuable resource for Peavey owners or the "Peavey curious." Peavey's customer service guys check the forums several times a day and answer questions as they can, but only on weekdays. |
#62 (permalink) |
Just wanted to note up that meanwhile i have had plenty of time to tweak its all buttons and bells ( the speakers wiring is corrected now as well), and am REALLy satisfied with the buy (in case if somebody is also in the phase of īto buy or not to buy?ī). Really cool amp! And costs nothing in States, accounting itīs features and price ratio.
Actually iīd say the mods are not that essential - it does pretty darn good tones in stockīsuitīas well. If only it were , say - 5...6 kg lighter Yesterday i discovered a totally different side of C50īs symbiosis with tele on itīs neck pickup , amp on itīs clean channel, reverb almost 0, gutar tone almost down - real "velvet jazz tone" to jam along with for example something similar to this for backround! Last edited by telbert twang : July 11th, 2008 at 03:16 AM. |
#63 (permalink) | |
The C50 410 is one of the best amps I've ever played - high value, sturdy. |
