Old April 6th, 2008, 08:12 PM   #1 (permalink)
T_red7882's Avatar
Amp kit progression
So, lets say you sucessfully complete a 5e3 kit. Is it safe to assume one could then move up to a tweed twin kit and then a blackface kit then a british style amp kit? or are there many other factors at play where the progressive idea wouldn't work?
T_red7882 is offline   Reply With Quote
Old April 6th, 2008, 08:18 PM   #2 (permalink)
Moderator
getbent's Avatar
Yes. That would be the progression.
Now, if you build your 5e3 and really only follow the layout and you don't learn how to use your multimeter, you aren't going to be too successful at more advanced amps... but, if you really get a handle on the 5e3, it would be a great stepping stone to the next level.
'never pet a burning dog'
Old April 6th, 2008, 08:22 PM   #3 (permalink)
T_red7882's Avatar
in what way do you mean to use the multimeter?
Old April 6th, 2008, 09:01 PM   #4 (permalink)
Moderator
getbent's Avatar
I mean that you come to understand how to and what it means when you measure voltages at different locations on the amp. You can follow a layout and often get an amp to fire up and even sound okay... but, as you work with progressively more complex designs that have more features, the interdependencies and complexities require the ability to troubleshoot and determine where your issues are...
Old April 6th, 2008, 09:36 PM   #5 (permalink)
Dacious's Avatar
A Fender Blackface amp with reverb and tremolo is amongst the most complex of amps to build without noises, a Marshall JTM style is simpler. The only exception being the Vox AC30 with topboost and tremolo which is apparently a nightmare due to using 3 tube sections for the trem.
Old April 6th, 2008, 10:07 PM   #6 (permalink)
T_red7882's Avatar
It seems possible to do though, right? Is there anyone out there who has done a vox kit or blackface kit?
Old April 6th, 2008, 10:19 PM   #7 (permalink)
tombm3's Avatar
Blackface Kit
My first kit was an Allen V-18. This is a beefed up version of a BF Princeton. This kit comes without step by step directions, just schematics and layout diagrams. No problems whatsoever. All the parts top notch and if you ever get stuck, David was only an email away.
The build time was less than a weeks time and 15 - 16 hours total. Since then I've gotten an Allen 5F1+ and an Allen Sweet Spot that I am currently building.
I may have had an advantage since my other hobby is amateur radio and I have put together my share of kits and projects. If you can solder well, follow directions or layouts and complete big projects you shouldn't have any problems.
tombm3 is offline   Reply With Quote
Old April 6th, 2008, 10:27 PM   #8 (permalink)
Dacious's Avatar
Oh yes, I mean it is possible. Just that a Marshall is basically a Bassman, so easier than a BF Fender which is probably a little more fincky to get right. I built Doug Hoffman's Vox schemo and wedged reverb in there, so anything is possible. There are BF kits around with the normal channel and trem removed which makes it easier, too.
Mr Allen's kits certainly get a good rap.
Old April 6th, 2008, 11:27 PM   #9 (permalink)
RomanS's Avatar
I built a JTM45-clone as my first amp, from a Weber kit - I'd say it is way less difficult than a BF Fender (reverb & tremolo circuits and two channels...) or a Vox (weird construction with preamp and poweramp split up on seperate boards placed in different locations inside that weird angled Vox amp cab).
Old April 7th, 2008, 02:06 AM   #10 (permalink)
Thats why I am sticking with the tweed builds less complicated and they sound great and if I want reverb or tremlo it is just a stomp box away with my Digitech RP pedals. Waiting for parts on my Super build but my 5e3 takes the Digitech Pedal very well it sounds great and has good verb and tremlo sounds plus all the other goodies it has to offer.
jh45gun is offline   Reply With Quote
Old April 8th, 2008, 12:44 PM   #11 (permalink)
Scott S's Avatar
Addictive, isn't it?
Once you have a success or two under your belt, deciding what to build next is the hard part!
- Scott
Old April 8th, 2008, 12:48 PM   #12 (permalink)
sjhusting's Avatar
It's a horrible, horrible disease. It's just not possible to stop - you always need a fix. Just one more.
steven
sjhusting is offline   Reply With Quote
Old April 8th, 2008, 01:22 PM   #13 (permalink)
TelZilla's Avatar
I built a Brown Vibroverb (fixed bias, two channel, Verb and Trem) as a first amp.
I think as long as your expectations are realistic, you take your time, and read read read before you pick up a soldering iron, you could build a BF Fender first time out, even if you're just painting by numbers.
That said, I'm not sure you'd want to build any amp without using a multimeter (sorta helps you figure out if you're in danger of incinerating tubes, trannies and the like)
But after you build a tweed, you might not want to bother
Thanks,Nick
Nec Aspera Terrent
TelZilla is offline   Reply With Quote
Old April 8th, 2008, 03:43 PM   #14 (permalink)
stax's Avatar
My first build was bringing back to life a Pro reverb using a Hoffman Board,
http://www.el34world.com/boardmaker/oldboardkitpage.htm
(scroll down for the AB763) and it was a real challenge.
After that I did a couple of 18-watt clones and then finished with a 5F1 Champ.
Guess as usual I did it all the wrong way round.:
Stax
stax is offline   Reply With Quote
Old April 9th, 2008, 01:57 AM   #15 (permalink)
T_red7882's Avatar
what do you think i should "read read read?" any books you recommend?
Old April 9th, 2008, 02:06 AM   #16 (permalink)
Following the voltages and signal flow is critical to troubleshooting an amp. I'd say equaly important is being able to read the schematics. If you can follow the schematic and are familiar with the layout, you can build almost anything with confidence.
pgambon is offline   Reply With Quote
Old April 9th, 2008, 07:40 AM   #17 (permalink)
RomanS's Avatar
About books: Dave Hunter's "The Guitar Amp Handbook" is an absolute must-read for every tube-amp newbie!
Old April 9th, 2008, 06:27 PM   #18 (permalink)
Scott S's Avatar
And if you like in-depth circuit analysis (i.e., no longer a newbie), you need this book! http://www.pentodepress.com/contents.html
- Scott
Old April 10th, 2008, 11:37 AM   #19 (permalink)
TelZilla's Avatar
I read the Hunter book, I think. It was the one with the gut pix of all these classic tube amps. He also does a thing where he walks you through the circuit of a 5F2, which I found really helpful.
But I think the internet is also a great resource. www.aikenamps.com, www.el34world.com, and the Weber forums (http://www.tedweber.com/cgi-bin/yabb/YaBB.pl) were all very helpful to me, as was this forum and www.18watt.com.
There's also some great information at www.thetubestore.com (no affiliation), particularly this, this, and this. There is some "salespeak", but also some good info.
I also read parts of an old US army tube manual from the 50's that was really helpful in understanding what's going on inside yer tubes. You can find it for free on the net (though I can't find it right now, of course).
Also, just be really methodical. I printed out the schemo and layout, and went from input jack to speaker on the layout and labeled every component with the corrseponding part info (r1, C6, etc.) in pencil. As I did it, I tried to think about what each component was supposed to be doing.
And if you haven't done much soldering, buy some terminal strips (supercheap at radioshack) and some hookup wire (ditto) and practice a bit before doing it on anything real.
Thanks,Nick
Nec Aspera Terrent
Old April 10th, 2008, 11:42 AM   #20 (permalink)
TelZilla's Avatar
found it!
Here's the book I was talking about: go here, and look for Basic Theory and Applications of Electron Tubes, 4th one down.
Thanks,Nick
Nec Aspera Terrent
