Speaker screw stripped out.....
I was changing the OEM speaker in my HRD and noticed that one of the bottom screws was not tight---and as I suspected; it is stripped out......when putting the new speaker in; this bottom left screw will not grab and tighten....[B]ideas how to fix this? Do the holes have a metal sleeve or something inside as the screws seem to be metal type screws; not wood screws?? [/b]Maybe just get a wood screw of like dimension or just a bit bigger and same depth wood screw and just screw it in?
Ideas?? |
Look at the others and see how they're arranged.
I've never seen a threaded speaker frame. If it's held in with machine screws, you're probably missing a washer and a nut and it's probably either rattling around the back of your amp or stuck to the speaker magnet. |
Well, found the problem......the screw insert was pushed a bit into the grill cloth. So, I pushed against the insert thru the grill cloth-----screwed in the screw and it pulled the insert in and tightened right up!
When I got my Weber it had instructions to only hand tighten the nuts and check them periodically.....glad you found the problem tho
Cheers ce24
www.motagator.net/slackwater "you can be happy or you can be miserable..the amount of work is the same" |
