Whoops, sorry.
They are adapters, similar to THD yellow jackets, allowing you can run el-84's in place of your 6L6/6V6's. I believe they turn your amp into Class A reduce and your output to drive the tubes into smooth tubey overdrive. |
#7 (permalink) | |
And regarding the myth that is "class A", please do some reading on this board. Plenty of references as to how that is all just so much more BS. Do a search. |
ahhh, give the guy a break. he's got 8 posts. as we know, class a is widely misunderstood by people because of sales people spouting things to get top dollar.
just to help you out, changing tubes won't change the class of your amp. nor will changing the bias. cathode biased el84's are not class a. as tremo said, if you do a search on this you'll turn up a lot of information on this topic. and not just on this board :)
clean as a whistle |
#10 (permalink) | |
if you like the sound of the amp you have but want to get more tube breakup, i would suggest an attenuator. i have a weber mass and i'm quite happy with it. hope that helps.
I've never used the GT version but I have used the THD 'yellow jackets' - 6L6 to EL-84.
As mentioned above they will of course not change the "operating class" of your amp but they will drop the output by as much as 1/2 and definitely change the feel and tone. I was using them in a 2-12, 60 watt Fender HR DeVille. The amps tone was a little darker, distorted earlier and felt a little looser overall. At the time and for this particular gig, they were exactly what I needed. YMMV. |
And it seems to me that you'd probably not lose much in the power stakes by swapping 6V6s for EL84s...they tend to have roughly the same output in most situations. 5 or 6 watts each single ended, 15-22 per pair, push-pull, depending on OT.
They will sound a lot different, though. Most people feel that 6V6s emphasize the lower and low-mid frequencies while EL84s emphasize the upper mids. If you can get 'em cheap, or try 'em in YOUR amp, I'd say go for it--what've you got to lose? |
Well almost...I have used ToneBones (which are pretty much the same as the substitubes) in my PR2. I liked it a lot!
Makes the tone a little softer in the high end and the overdrive slightly smoother and more gradual. It also makes the amp sligthly quiter, but very subtly. Now I am back to the 6V6:es but that was because I transferred the Tonebones to my Super Champ. They made a very positive contribution there as well. Overall I think tube adapters are great fun. I also have the Tonebone Triode version which give a really loose feel and significantly lower headroom. Theyīre also great for recording when you want a slightly different flavour. |
#14 (permalink) |
Thanks for the positive input, folks.
I have used, bought and sold enough amps to know that changing a tube or two is not gonna change the operation of an amp. As I stated, I was more interested in the tonal changes of switching. And, I also know that if you want steak, order steak - not fillet of steak-umms. I found mention of the 928's and was curious - you guys have been a big help. Thanks again. |
I tried them in my -78 Twin Reverb. Replaced all four of the 6L6-tubes and got a nice sound. It didnīt turn the amp into a Vox though, but the sound got slightly "Voxier". Or more of that Laney AC-30, or Peavy Classic 50, sound. It definitely didnīt sound exactly like them, but it sure got close. It lost some of the bottom and the warmth of the Twin reverb, and got a nice bright sound. It sounded a bit compressed almost, and there was a change in volume also. The overall sound was at bit smoother and quieter. Still, I couldnīt get the amp to break up though. Well maybe it would sooner or later, but then again Iīd rather not be in the same room as the amp with the volume above 5. I also tried the amp with two of the output tubes pulled, and with only one of the speakers connected. With that setup I got quite close to the sound of the Blues Jr Tweed I had next to my Twin. All in all I found that I missed the original sound of my Twin, which is the reason why I got it in the first place. I have to say that it was nice with the EL84 tubes for a change, but if you want the real deal I guess youīll have to get a Vox or a Peavey or whatever. You could also use two of the EL84īs with two of the 6L6īs and get a nice combination. Still, I found that it wasnīt quite a Twin Reverb and not quite a Vox, or not quite anything at all really. Just a nice change. I bet they would be useful in a studio, though, as itīs fairly easy to get some different sounds out of one amp.
