How do you deal with icepick via amp settings?
My Esquire has Fralin stock tele PUP and when playing through my twin reverb I set the amps settings to the bridge only selection on the guitar. It seems like an almost endless way to do this and I was wondering how you guys do it. I just have my treble on 5, mid on 5, and adjust the bass on +/-1. This keeps all those glorious trebles around but at the same time harness' the icepick beast.
What do you guys do? I know every setting is different, but are you more prone to messing with the bass, mid, or treble? Also isnt a bright switch on a Fender amp kind of rendundant? Does anyone use it? |
I did use the bright switch when I switch guitars from my tele to a humbucker equipt strat. The tone worked out good with no other changes to the settings between those particular two guitars. What I was doing about the icepick bridge thing though was setting the tone settings for the other settings on my tele, and then when I go to the bridge, rolling the tone off to about 6 or so. That works fine on my setup.
Weber Beam Blockers!!! www.webervst.com
Nobody uses thier amp controls? I'm not going to mod my amp when all I need to do is adjust the bass level. I could also lower the treble or adjust the mid all these things take care of the icepick I was just wondering what everyone else did. Just to clarify the Esquire has a tone control in one position and none on the other 2 (1 has a cap). So I adjust the amp to the one position with no tone control because there is no tone control in that one position.
Yes, people use their tone controls. It's evidently not working for you. Sometimes an amp/ speaker combination produces a "BEAM" of harsh high end, that the tone controls will tame, but in the process extuingish all of your useable high end. That's where the "Beam Blockers" shine...no non reversable mods either. This is not what "everyone else" does, "everyone else" does not have this problem, but some do report this malady, and these get great reports from these folks......just a suggestion.
#9 (permalink) | |
I used to just have my amp set on 5 for everything and adjust with the guitar tone control but now that I have an Esquire it's not that easy. I could put a tone on the 1 position without it but I'd rather not because that is what's unique about the Esquire, having a bridge only position. I like to set it with the position w/ tone control about 60% then all I do is switch from no tone to tone @60% rather than have to mess with the knobs. |
Yes, that's what most players do, and that might take care of it.....sometimes... but only where your standing. That's why players usually like their amp in a certain position in relation to themselves on stage. The problem with the "Ice Pick" high frequency beam is that when you adjust the amp for "Your Tone" from one position on stage, or wherever.... and you move.... "Your tone" changes, and if your movement is directly in front of the amp the change will be for the worse. The high frequency "Beam" coming from the center of the speaker, travels faster than the rest of the more pallatable frequencys, thus appears harsh and brittle. A beam blocker appears to send all the frequencys out together, blocking the harsh highs from emminating, unimpeded from the center of the speaker by themselves, and thus a more uniform sound everywhere you move, and NO BEAMING. Many Icons (Stevie Ray comes to mind) use beam blockers in one form or another, as well as many working players. We are apparently talking about two different things.....if you haven't experienced this...you will, and "Tone Controls" will NOT solve it.
#11 (permalink) | |
I'll look into those weber things. |
#13 (permalink) | ||
I'm curious. Since you've added a neck pickup, what do you get out of each of the three positions? I've never had an Esquire, my Teles are two-pickup setups with controls that are essentially the same as the post-67 Fender setup. The exception is one Tele with separate tone controls (stacked pot), but I plan to switch that back to master volume, master tone. I generally set my SFDR controls to about 1 on the bass and about 5 on the treble. For a Tele with a slightly warmer tonal character I'll set the tone up a number or two. Then I adjust the tone control on the Tele somewhere between max and 2/3. I do that when I plug in the Tele, then I usually leave the settings alone. I like my Teles set up with pickups, pots, caps and wiring so I can generally switch between pickup settings without having to do a lot of adjusting the tone or volume during playing. I play mostly at home by myself, and I realize my setup and approach may not have much relevance for a gigging environment. I'd like to try a beam blocker. |
#14 (permalink) |
This is a struggle for me, too. I strive for a really clear tone where the low strings are as piano-like as possible, but I roll off just enough treble to tame the icepick. Bright switches (or channels) are great for some darker-sounding guitars, because then you have more flexibility with the treble control -- it's not just dimed.
Simply taping a circular piece of cardboard over the center of the speakers does work, but I imagine the Beam Blocker is even better. |
#15 (permalink) | |
1st position=PUP+tone control 2nd position=PUP no tone control 3rd position=PUP no tone + .047 cap (bassy sound ala "I walk the line" or "I still miss someone" It's funny that the 1st position with the tone turned all the way off sounds identical to the 2nd position which has no tone. I figured there would be a slight difference maybe the 2nd position would be 'hotter' sounding but to me they sound identical. Also the way I have it wired the tone cap is a jenson .047 and the bass cap is an orange drop .047 and to me I can hear a slight difference between the 1st position with the tone all the way up and the 3rd position...Neither one is 'better' but I think the jenson cap sounds a tad warmer. Just food for thought... |
#17 (permalink) | |
