Old March 28th, 2008, 04:16 PM   #1 (permalink)
andrenighthound's Avatar
how long does it to take for a amp to fry if on with no speaker?
i had one of my amps on for about 5 seconds accidently without a speaker plugged into it. The amp still sounds fine. Did I possibly hurt the amp? If so, what part of the amp would get affected the most? Also, how long does it take to generally fry an amp by having it on with a speaker attached to it?
thanks.
"Blues in a doggy bag, is what I got to eat!"
www.andreandthenighthounds.com
andrenighthound is offline   Reply With Quote
Old March 28th, 2008, 04:43 PM   #2 (permalink)
If your amp has a shorting jack, there's no problem. Tube amps would rather have a shorted output than an open circuit.
If the speaker connection was open, with no load, damage could happen with just a couple of big chords. You would get flyback voltages from the output transformer, which can cause the OT to arc and burn internally. You might also see arcing in the tubes.
Most newer Fender amps have flyback suppression diodes in the output to prevent or minimize damage.
Billm is offline   Reply With Quote
Old March 28th, 2008, 07:02 PM   #3 (permalink)
Moderator
Joe M's Avatar
Hey Billm, welcome to the forum. I'm assuming you're the same Billm that's on "another" forum who has tremendous insight and helpful tips on amps. Glad to have you and your knowledge on this site.
Joe M is offline   Reply With Quote
Old March 28th, 2008, 08:21 PM   #4 (permalink)
Can you explain the principle behind this? If there is is no guitar plugged in, how long can the amp be on without causing damage? Seconds, minutes?
larry
Larry F is offline   Reply With Quote
Old March 28th, 2008, 09:22 PM   #5 (permalink)
surfoverb's Avatar
6 seconds.
Old March 29th, 2008, 04:03 AM   #6 (permalink)
i used the amp tonight for a 3 hour gig and it sounding fine...can i assume my amp did not get damaged?
Old March 29th, 2008, 04:45 AM   #7 (permalink)
Scott S's Avatar
I think so. Might have to test it a couple more times to be absolutely sure.
Scott S is online now   Reply With Quote
Old March 29th, 2008, 12:00 PM   #8 (permalink)
EMan's Avatar
Hey Bill, glad to see you here!
If the amp still works fine, then you didn't hurt it.
EMan is offline   Reply With Quote
Old March 29th, 2008, 12:10 PM   #9 (permalink)
klasaine's Avatar
I'm "pretty sure" that if you're not actually putting a signal into the amp, ie; playing through it, you won't hurt it.
That may not be true for a true class A amp cranked up to 10 without a load though.
