Need advice: using the headliner's amp
I have a pretty big gig coming up at a semi-legendary Dallas venue. I'll be playing electric (tele of course) & lap steel to back up a local singer-songwriter. We are opening for an established roots rock band.
The headliner has suggested (thru channels) that I use their guitarists amp for our set (it is really important to them that we setup & tear down *very* quickly). He described the amp as a: "Fender 57 refurbished". Not sure exactly what that means. I don't know the headliner or have their contact info. All I really need to get by is a good clean tone. I don't need any overdrive for this gig. What advice could you give me: Should I trust that that this amp will be capable of delivering cleans? Should I bring my own amp? Also, what's the proper etiquette for an opening act using the headliners gear? Is it ok to adjust the amp settings to my preferences? Not trying to be *TOO* dense here. This is a potentially breakthrough gig & I don't want to blow it - either by generating ill will or by having bad tone. Any thoughts? Thanks. =jason |
| Sponsored Links |
Bring your own amp. If they ask you to use the headliners amp at soundcheck, then give it a try. If it won't work, you should be able to use your amp as long as it can be struck off the stage fast and the soundguy has a spare mic for it. Smaller the combo the better, no full stacks LOL.
former sound guy here. my advice would be to bring a small combo amp that you know & feel comfortable with to the gig. Why? The guitar player for the headline act may not actually be in the loop on this conversation. He may not like you playing through his amp -- and he may not let you change the settings on the amp, either. I've seen this happen many, many times. People generally don't like other people playing through their stuff. I don't.
So: no pedal boards, no combo amps, nothing that requires a set-up or tear-down. One plug, a little amp on a chair and one speaker to throw a mic on. If you can get by with this, you'll make life easier for everybody -- who will in turn make life easier for you. (If you get to the gig and they really want you to use that exact amp and you can get a usable (not ideal but usable) sound out of it, go with the flow.) |
Moderator
I'd expect the amp to be some kinda tweed, most likely a Deluxe (but who knows?). I'd really hate to have to plug into someone else's amp and have to get a tone real quick. Not that there's a huge likelihood that it won't be a good-sounding rig, but if the other guy doesn't go for the same kind of tone I do, that could be a hassle.
I have a Yamaha Magic Stomp (think "Pod"), and I'd probably bring it along as a backup, and use it at the very least as a tone-shaper in front of the other amp (if that amp didn't sound like me). I would definitely bring a note pad and write down the settings on the amp, so if you did need to adjust it, you could turn it back to his settings when you're done! Cheers, Tim
http://www.moodswingers.org |
thanks everyone...I suppose I have been completely overlooking the fact that we will have a soundcheck.
I'll bring a little 1x2, keep it just off stage & be ready for either outcome. =jason |
I completely concur with all of the above. Always, always bring your own gear. They are hiring your band, and it doesn't really matter in all seriousness what the headliner likes. These opening things are stressful enough without playing on unfamiliar gear. The 2 minutes it takes for you to remove your equipment is not going to make any difference at all in the overall scheme of the night.
I don't know who the jerk is in the other band, but tell him to go and intercourse himself. You have every right to expect nothing but a professional atmosphere and to be treated with dignity and respect. MMMMAAAANNNN, the stones on some people!!!!!! BTW, I can't count the number of times I have done one of these things and not got a sound check. Bring your own stuff, don't discuss it any further and just set up, if they ask about it, be very adamant that you will be using your gear. PERIOD. Don't be nasty, just be firm and convicted. Jason-I know you are trying to be cooperative, and not make waves, but please believe me, whoever asked this of you could care less about how you feel regarding this. Stand up for your musical voice. Let the dog lay until you get there, play dumb and insist on playing your own stuff. This should be an enjoyable and exciting gig for you guys. I have never, ever been happy with my performance or tone when I use someone elses gear. Also who knows, the player whose gear you are using may not want you to touch it. So you get up there and now you can't get the tone you want. By all means, BRING and PLAY on your own gear.
![]() éí 'aaníígÓÓ 'áhoot'é Would you mind holding this bag while we go through the custom shop????? Redd Volkaert is a Jedi Knight at one with the Force!!! |
Yep. Always, always use your own gear. The amount of trial and tribulation avoided this way is worth every bit of extra hassle and you won't regret it.
I recall the last time I used someone else's rig. I was assured that they would have a "really nice amp" there, and I fell for it. It turned out to be a Marshall JCM800 with a 4x12 cabinet, no reverb. It was a country gig - not exactly a good match. "Nice amp" for a Zep tribute band, I suppose. After trying the Marshall for about 20 seconds, I was running out to the parking lot to retrieve the DR hidden in my trunk. Whew!!
---------- Tech Geek and Sensitive Artiste String bender ordinare! |
Please, please, please at least bring your own little combo along! Then you'll be covered for any situation. Is your drummer playing his own kit? There's at least a half hour set-up/breakdown right there. You can be up and running and broken down and gone within minutes.
Just remember - Go with the flow!! mud
www.mudbean.com "Do ya want it to be interesting, or do ya want it to be true?" "So far, it's neither." |
Bring and use your own gear after all its you playing and you want to sound your best. I went to a party last year where some guys were going to jam it was a birthday party for a guy who used to play who had medical issues. Well I did not take my amp the guys brother told me there would be amps there. well there was not as some guys did not show up so he went and got an amp. I should have went and got my own as the amp was on of those Marshal Mini Stacks and to me IT SUCKED. It feed back a lot and I could not get it set high enough to cut through the mix. The guy running the PA miked it with a mic that did not work righ so I could hardly be heard. If I would have brought my own amp there would not have been any issues it would have been powerfull enough to cut through the mix.
FWIW, with one notable exception, nearly every time I have been told, "You don't need to bring your rig - there will be amps provided." It became a huge clusterf**k. Just throw a little combo in the car ... Be Prepared.
mud
Always bring your own amp. Use their drums and bass, but always bring your amp. I never let anybody but friends play through my amp and even then, no pedals. You want your tone, so bring your amp. An amp isn't a time issue like drums to interchange.
Please, please, please at least bring your own little combo along! Bring and use your own gear Just throw a little combo in the car ... Be Prepared. Always bring your own amp so bring your amp. Seems to be a central theme to this thread...
#14 (permalink) | |
WHICH might actually mean you have a good monitor mix using the other guy's amp anyway? ya never know, so i think you're doing good by draggin your amp...just weird that they would REQUIRE you to use their amp... i'd just ask the other guitar player when you get there...like others have said, HE's ultimately the one you want to deal with probably - and ask if you can adjust the knobs... btw, where are you guys playing? who's the headliner??? |
stage gear?
I've never had good results using other Backline gear. Bring whatever you need to get the job done. But be sure you can set it all up in under 3 minutes. (I bring my own mic/stand/extension chord). And my 4x12 cab only takes about 30- seconds longer to get ready than my combo amp. Also only takes up about 8 inches more stage space. (but people love to complain
I've seen guys show up with 3 amps, 10 feet of pedal board, 3 guitars and then waste 20 min. fusing over their gear. This makes all people weary of guitar players for years to come. I've lost lots of stage time because these boneheads also take 25 min. to get their crap off stage after. Don't put your amp on a chair if your not used to it. Totally changes your sound. I also face my amp across the stage at some gigs. This keeps the soundman from complaining about my volume.
"How little I know inspires me tremendously! I'm a huge fan of other people's playing." Bonnie Raitt |
#17 (permalink) | |
I still didn't run out and buy one, and I still had my BFDR in the trunk just in case. Always good advice.
#18 (permalink) |
I'd go for it if it really is a '57 tweed twin ... and it's in perfect operating condition ... and the owner doesn't mind you using it and changing settings.
What are the odds of all that being the case? I always bring my own amp. |
