Turning Combos into Heads
Just want to get other guitarists thoughts on this.
I currently have 2 tube heads, and 2 tube combos. Since I have cabs in 2x10, 2x12, and 4x12 combinations, I'm thinking about turning the combo amps into heads, giving me the freedom to pick and choose what I need, per gig. I'm also currently building a 1x12 cab, for the smaller gigs or practices. The woodworking aspect is not a problem, as far as making new enclosures for the heads. I've looked into trying to do some trading, combo for head of the same model, but haven't had much luck. So, have any of you done this? And if so, have you ever regretted it? Or, any pitfalls that I'm not seeing? The tube heads I have are a Dr. Z Maz Jr., and a hot rodded Epi Valve Jr.. The combos are a Mesa Maverick 2x12, and a Peavey Classic 30. Later...........weedman |
I was going to ask pretty much the same question.
I'm guessing you'd want all the speakers to be roughly the same in terms of the wattage they're recommended for. Ie if all your amps are in the 15 - 30 watt range, also have all the cabs running speakers that can handle 30 watts and still sound good at 15. You wouldn't want to run a 100 watt head through a speaker rated at 25 watts, I don't think. Not for too long. But is the opposite true as well? If you're running a lower watt head (or head part of a combo) through a speaker set that can take a lot of watts, will the speakers not have to work as hard and maybe not sound as good as when they're pushed a bit? I suspect this may make more of a difference if you're aiming for distorted tones. But, this is all just a guess by me. Amp gurus? Cheers, Geoff |
