Attaching Blackface Handle
I'm restoring an old SF combo; I've just received my replacement handle from Hoffman, but suddenly (and embarrassingly) realized that, after all these years of using them, I have no idea how these things should be attached. There's the strap itself, the two chrome end pieces, 2 T-nuts, and two screws. Anyone willing to help a clueless noob out?
| Sponsored Links |
#2 (permalink) | |
The screws go through the chrome caps, then through the strap slot and then screwed into the t-nut. When you tighten it, the chrome caps will dig into the tolex helping to hold everything in place. If this is a brand new cab without the holes drilled, first suggestion is to get the correct measurements from an existing amp. Otherwise, you can use a ruler to find the center on the top of the cab and then measure out the distance between the screw holes by laying the strap and caps on the cabinet....the strap should be able to go flat and then have room to pull up with your hand underneath it.
Mama always said, "A little tone is good for the soul." |
#3 (permalink) | |
If it is a SF it should have had a handle so I would suspect the T nuts are still there. If there is a shielding plate over the wood just put a bolt in and see if it grabs threads. If so put the new handle in. If there is a plate over the holes the T nuts cannot go anywhere. Is the plate factory or did some one add it? If it is origional like I said I would suspect the t nuts should be there yet.
The shielding plate has a Fender serial number sticker on it, so I assume it's original. I tried just screwing it down, but it looks like the screw is pushing out the shielding plate. Am I going to have to take this plate off?
Just take the one of the bolts to the hardware store and match it with a shorter one so it does not push on the plate. Since your handle is a repo handle he may have included longer bolts then necessary. The folks at the hardware store can make sure you have the right thread pitch so I would ask to make sure since this stuff is new to you. You did not say are the T nuts still there?
#8 (permalink) | |
Well still does not sound like too big of a deal. Take off the plate and put in new T nuts and screw in a bolt to see how much more is sticking out. Then get the right size bolts and put on the handle then replace the plate. You could drill a couple of holes in it and then just screw it to the top board using small screws that would not go through the board. Or reuse the staples.
That's what I'm going to have to do; while I realize that staple guns are like blowtorches - "every guy should have one" - I don't, so that's another purchase, unless I can pull them easy and hammer them back in.
#12 (permalink) | |
