| View Poll Results: 5E3: 12AY7 or 12AX7? | |||
| The stock/normal 12AY7. |
45 | 72.58% |
| A 12AX7 for more gain, crunch. |
2 | 3.23% |
| Sometimes I switch between both. |
10 | 16.13% |
| Neither a 12AY7 nor a 12AX7. |
5 | 8.06% |
| Voters: 62. You may not vote on this poll | |||
A poll for you 5E3 owners.
Which do you prefer in your first preamp slot: 1. The old, lower gain, stock/"normal" 12AY7. 2. A 12AX7 for more gain. 3. Depends on my mood - sometimes either one. 4. Neither a 12AY7 nor a 12AX7. If so, which 12A*7 variant? What kind of guitar(s) and music do you play through your 5E3?
- 3 Gibsons, 5 Teles, assorted other guitars, about a dozen amps, about two dozen pedals, a Smith & Wesson SW40VE, & a .40 SIG Sauer P226R = too many toys, no money, carpal tunnel, and a serious hearing problem. |
you got me checking mine i got from jim at li'l dawg. he didn't give me a tube chart to use so i wasn't sure the order to put mine in.
from left to right mine is 2 RCA 6l6's followed by a raytheon 12ax7 and then a raytheon 12ay7. how should it change my tone if i switched my 12a**'s ? mine as set up is clean as long as i'm playing soft but gets dirty quick. would love a little more headroom in mine |
I do not own a 5E3 (yet!). I do have a cheap Kustom Tube 12a practice amp. It came with a 12AX7 preamp tube that was too crunchy for me. I like overdrive, but I like it kinda smooth and not over-the-top. The stock 12AX7 got over-the-top when I turned the GAIN knob 1/4 of the way!
I put in a Phillips 5751, which is (if I recall correctly) mid-way between the 12AX7 and the 12AY7, gain-wise. I now have fuller use of the GAIN knob, I can still crank it, but I get nice, bluesy overdrive without too much distortion. I like to play mostly clean, but with a bit of overdrive when I dig in. Somewhere online is a nice chart of the relative gain levels of different 12An7-compatible tubes. I can't find it at the moment. FOUND IT!!
Two Teles + One Strat + Four Acoustics (6, 6, 12 & solidbody 6) + One Bass (5 strings) = 53 strings total |
#5 (permalink) | |
The first slot is cathode biased for a 12AY7, but putting a 12AX7 in will make for more crunch and preamp gain. I put a cathode switch in my 5E3 so I can go from stock 5E3 to Marshall's 12AX7 values (stock 820/25uF or Marshall 2.7k/0.68uF) and with a 12AX7 and Marshall values it actually seems a little cleaner and almost louder (and obviously trimmed of a little Bass). As mentioned, you can swap 12A*7 types for others for changing overall gain, but as you can see from my cathode switch, each 12A*7 tube has it's own cathode values it likes... so this changes the "gain" dynamic when just dropping them into a slot meant for a different 12A*7 tube.
By the way, I voted for both.
I like both sounds so I've been swapping in and out 12AY7 and 12AX7, depending on what I feel like playing (old Blues or Hard Rock), the guitar (Tele, P-90s, or Les Paul), and my mood.
i just swapped mine....still dirty and crunchy but seems a little quieter, less hum of which it wasn't really a prob before but this is an improvement.
lol..thnx for getting me to look. if still undecided about a speaker for yours i have a jbl d130 15 inch i had rebuilt by weber. its 8 ohm. i've been planning to have jim make me a duplicate cab for my dawg so i have 2 15's..a bit of a mini stack. but jim to my knowledge isn't building cabs again yet. would consider selling it as i could use the money too. got about 150 in it. |
I haven't put it in yet but in my Bravo I have a 5751 and I will be putting that in...I like em!!
ce24
http://www.facebook.com/pages/Slackw...21128657913864 www.motagator.net/slackwater the dude abides |
5e3 + 2x12" with webers and TELECASTER
5E3 with 12ay7 first.... excelente headroom, character, blues and clean rock sounds.... even accepts jazz ES335 at lower settings with the 12ax7 it is to much into "one trick pony" distortion.
Watch my Blog with DIY Tube Amps and Boutique Effects from CHILE : www.richon-caster.blogspot.com |
I'm actually using a GE 6072 in slot 1. I don't like the 12ax7 in the first socket; too gainy for me. As a matter of fact, I've got a GE 5751 in the second slot, too.
But Johnny, you can put anything your little heart desires in your JTM5e3 steven |
#12 (permalink) | |
"JTM5E3?" HAHA Like I said, it's all stock, but I can swap in Marshall cathode values for V1 with the mere flip of a switch. As such, I prefer the 12AY7 when in stock mode... I kinda like the 12AX7 when in Marshall mode (especially with the Solid State rectifier and 60uF filter cap switched on and the 5Y3 switched off). When in this configuration, sure it's a one trick pony, but the pony has 12" fangs and batwings :)
I have a Baldwin 12ax7 in my first slot which according to the amp tech I got it from while labled 12ax7 it is more of a cross between the 12ax7 and the characteristics of a 12ay7. These tubes were made for Baldwin Organs and are supposed to be a more refined (Higher Specs) tube than some of the standard tubes. What I was told anyway as was I was also told that the tubes you find in ocilliscopes are a higher spec too.
#14 (permalink) |
I had two 12AX7s in mine and thought it sounded pretty good. Then I put in an NOS rectifier and a 12AY7 in the first slot. A VAST improvement. Far less boxy sounding and more sparkle before the grind sets in. Much more versatile with the 12AY7.
#16 (permalink) |
I like both. Sometimes I've gone for a 12AU7 or the 5751 as well.
Only own two electrics....tele and strat....and they sound wonderful through my slightly less 5E3...oh, did I mention that it only has one 6V6???? Perhaps I shouldn't be here?? |
#17 (permalink) |
i will use either....depending on the particular guitar i'm going to be using.
in general, those guitars with hotter P-ups get paired up with the AYs, those with lower output P-ups get the AXs.... |
#19 (permalink) |
I voted for the stock 12AY7. I don't play a 5E3 though. Hope it's okay
I play a tweed Tremolux 5E9-A copy made by MG Music (brazilian co.) which is similar to a 5E3 with added tremolo and different, more crude PI. I also use a 12AY7 on my homebrew Champ 5F1 'cause it tames that tweed 'fuzzyness' a bit and I like it better that way.
"This is so cool I have to go to the bathroom!" Calvin |
#20 (permalink) |
I've been using JAN 12AY7s in my 5E3 and 5F4 (and sometimes my 5F2-A). I play a tele and a Gretsch 5120 with Fralin P90's. I mess with old country, a little honky-tonk, some western swing and a little cajun/zydeco. I like a pretty clean sound and the 12AY7 seems to have a little creamier distortion when pushed compared to the harsher 12AX7. But, hey, what do I know. I'm just a fiddle player anyway.
--- "Speak English Doc, we ain't scientists!" --- |
