Old March 9th, 2008, 07:20 PM   #1 (permalink)
tele-martini's Avatar
Finally 5E3 Perfect !
After 2 weeks of battling hum and crackling in my 5E3 build I've finally fixed everything. After splitting the grounds from the power and preamp sections of board to different sides of chassis I finally cured the problem. I also added sheilded cable w/grounds to all inputs and all the vol and tone pot wiring. Now you have to turn the normal channel past 10 and the bright channel past 8 to barely get an audible hum from her. Very quiet ! Thanks to all that answered posts, PM's etc. w/suggestions.
Time to pour an ice cold beer and celebrate!!!
Gene
Nothing is more beautiful than a guitar, except, possibly, two.
...Frederic Chopin
tele-martini is offline   Reply With Quote
Old March 9th, 2008, 07:42 PM   #2 (permalink)
Congrats on getting it all fixed up quiet.
jh45gun is offline   Reply With Quote
Old March 9th, 2008, 07:43 PM   #3 (permalink)
Guitarslinger1's Avatar
Mmm beer...
Guitarslinger1 is offline   Reply With Quote
Old March 10th, 2008, 02:00 AM   #4 (permalink)
Hannibal from the A-Team would probably say:
"I love it when an amp comes together."
Very cool!
I just started my amp build Friday. My gal's father died, so things have been moving very slow :(
Old March 10th, 2008, 02:12 AM   #5 (permalink)
Trimmed&Burnin's Avatar
Good on you Gene! Are you goning to post sound clips??
Keep your lamp Trimmed And Burnin
Shannon,
Trimmed&Burnin is offline   Reply With Quote
Old March 10th, 2008, 02:41 AM   #6 (permalink)
zeeman's Avatar
Awesome! Congrats on getting it going. Great amp.
zeeman is offline   Reply With Quote
Old March 10th, 2008, 12:04 PM   #7 (permalink)
One of my 5E3 builds had problems with buzzing and hissing. I had no crackling issues though. When building it, I did an experiment with the grounding bus. I added a 12 gauge copper wire along the top of the board and soldered all grounds to it. The end was then soldered to a lug on the transformer end of the chassis. It looked really good. I got the idea from another post in another forum, far, far away in another galaxy. Once I cut the ground bus wire and split the ground locations to opposite ends the amp cleaned up to very quiet operation.
I have read several articles on "star grounding" and, from experience, concluded that the simplest method works the best.
SEK_Hakuna is offline   Reply With Quote
Old March 10th, 2008, 12:13 PM   #8 (permalink)
sjhusting's Avatar
Read Doug Hoffman's take on grounding. I use his scheme and it works right every time.
Here's the short version:
Line ground to a bolt way over on the power transformer side of things
Power section ground on the power transformer side of things.
Preamp ground as far away as possible from the other two.
Basically you want to avoid heavy currents flowing around input stages.
steven
sjhusting is offline   Reply With Quote
Old March 10th, 2008, 09:34 PM   #9 (permalink)
Very cool!
I'm very sorry to hear of your gal's father passing. My sympathy is with both of you.
Right now I'm using a "Made for Fender" Emenence spkr. I've decided to go with a Jensen P12Q ultimately . I'll post sound clips after installing it.
steven
Yep.Don't have to convince me. Fully agree and lesson well learned .Took 2 weeks of pulling my hair out to find out on my own. Note: Hair loss is not something I can afford these days.
...Frederic Chopin
Old March 11th, 2008, 04:28 AM   #10 (permalink)
That ground lesson is one that was a hard one to learn...
Sometimes I throw a build together and have to relearn it :)
Aiken's description of a "river" was one that stuck with me. Competing currents, etc.
Thanks for the mojo tele-martini... she's not feeling too well.
Old March 11th, 2008, 04:00 PM   #11 (permalink)
TelZilla's Avatar
steven
+1 on that.
Thanks,Nick
Nec Aspera Terrent
TelZilla is offline   Reply With Quote
