Old March 3rd, 2008, 02:13 PM   #1 (permalink)
ce24's Avatar
PT vs OT difference
Well I've got the amp build bug and I have come across a number of old amplifiers of various types that I can scavenge what looks tobe some real nice transformers and lots of other parts. I've been looking at different sites and haven't been able to find some designation of how to tell them apart...They look the same in their different styles. any web sites to look at for info. plus what wires do what?
Thanks
ce24
OK PT multiple taps
OT has three wires coming out of it.
www.motagator.net/slackwater
"you can be happy or you can be miserable..the amount of work is the same"
ce24 is offline   Reply With Quote
Old March 3rd, 2008, 05:08 PM   #2 (permalink)
tazzboy's Avatar
PT = Power Transformer
OT = Output Transformer
tazzboy
Old March 3rd, 2008, 05:23 PM   #3 (permalink)
ce24's Avatar
I wasn't very clear was I? I know OT and PT, if they aren't stamped is it just the number of wires that tell you which one it is?
Thanks
CE24
Old March 3rd, 2008, 05:24 PM   #4 (permalink)
"I have come across a number of old amplifiers of various types that I can scavenge"
Sounds interesting, TELL US MORE!
I may over simplify a bit, but along with some other guys' tips this may help you:
The OT has two of its leads - its secondaries - attached to the speaker jacks (or at last one of them, one may be grounded to the transformer Tweed Deluxe OT style, in which case only one of the leads go to the speaker output).
The PT on the other hand is connected to the rectifier (tube or SS), the pilot light, the mains switch et.c. and is often located farthest away from the input tubes.
Could you post a few pics of the amps? That would make it a lot easier to help you. Also if you could tell us what brands and models the amps are.
Good luck!
4 Strings is offline   Reply With Quote
Old March 3rd, 2008, 05:31 PM   #5 (permalink)
ce24's Avatar
I'll do that tonight when I get home...Thanks
CE24
Old March 3rd, 2008, 06:25 PM   #6 (permalink)
PTs generally have:
2 Primaries (usually Black wires).
2 Secondaries (usually Red wires), with a center tap (usually a Red-Yellow wire).
2 Tube Heater Filament supplies (usually Green wires). Sometimes a heater center tap too (most times Green-Yellow).
Usually 2 rectifier heater wires (most often Yellow).
Sometimes there is a bias supply wire too.
OTs generally have:
A black ground wire.
A main voltage wire (usually Red).
A wire for each tube's (or pair of tubes) plates (usually a Blue and a Brown).
One to three secondary wires (different impedance taps of varying colors).
If you got the trannies from the same amp, the PT is generally the larger of the two trannies.
Old March 3rd, 2008, 08:39 PM   #7 (permalink)
ce24's Avatar
little red chicago
here is one amp...making sure I know how to post pics...
Cheers ce24
ok got it I'll post again after i take the pics and get them on my band site.
Old March 3rd, 2008, 08:44 PM   #8 (permalink)
quackerz's Avatar
That thing is tiny!
quackerz is offline   Reply With Quote
Old March 3rd, 2008, 10:11 PM   #9 (permalink)
ce24's Avatar
here's the pix of amps n stuff
some are tube radios but I'm sure that something can be salvaged.
What do you think? I also have 3 butter tubs of orange drops/the red colored ones too. and 3 tubs of resistors that I'm getting.
Cheers
ce24
guess the pics wont play and I cant delete this post I'll try one more time
