Old April 5th, 2006, 06:28 AM   #1 (permalink)
gitarjoe's Avatar
Putting nylon strings on a steel string..
acoustic. I was thinking about doing this to my ovation. I wanted to go for a nylon string tone, so I was thinking about doing it. Will this work? Will it hurt the guitar? Do I have to make any mods? thanks.
Just my two cents.
gitarjoe is offline   Reply With Quote
Old April 5th, 2006, 07:28 AM   #2 (permalink)
ruger9's Avatar
Re: Putting nylon strings on a steel string..
I'm planning on doing the same thing. It won't hurt the guitar, but I don't know how it'll sound & play. They do sell ball-end nylon strings, I bought a pair somewhere...can't remember where...it's been awhile...
Old April 5th, 2006, 10:31 AM   #3 (permalink)
jwsamuel's Avatar
It won't hurt the guitar but you may find the neck becomes too narrow to play properly. Nylon strings are thicker than steel, so there just may not be enough separation for you to be comfortable.
Be sure to get the ball end nylon strings.
Jim
jwsamuel is offline   Reply With Quote
Old April 7th, 2006, 03:35 PM   #4 (permalink)
Joe-Bob's Avatar
You won't necessarily have to have ball end strings if you know how to string a classical (tie the strings properly) The problem you're gonna run into is the nut and tuners. Nylon strings are pretty fat, you'll have to ruin that nut for steel strings. Also, classical guitars have huge tuner 'posts' because the strings take a lot of string length to come up to pitch. You'll almost certainly run out of room on the standard tuner posts.
"German is the language God uses when He really means business." --FZ
Old April 7th, 2006, 07:28 PM   #5 (permalink)
gitarjoe's Avatar
Thanks guys..
I gues its just not worth it. I guess I will try to find an elcheapo nylon string.
Just my two cents.
Old April 8th, 2006, 02:20 PM   #6 (permalink)
Also a major problem is that it'll sound tripe...
The bracing on a steel string is FAR heavier than that on a nylon strung guitar - It'd be quiet and trebly.
jammy is offline   Reply With Quote
Old April 8th, 2006, 11:22 PM   #7 (permalink)
moondoggie999's Avatar
tried it, this is what i noticed
The nylon strings don't have the tension to really drive the top of a steel string acoustic guitar. The top is too heavily braced to counter act the tension of the steele strings and the nylon strings will just kinda flap away without really pushing the top to make a sound.
A lot of times, the nylon strings would break for me when trying to put them on a guitar meant for steel strings.
You probably know that if you put steel strings on a nylon string guitar, it can rip the bridge off or worse.
You start off playing guitar to get chicks and end up talking with middle-aged men about your fingernails - Ed Gerhard
moondoggie999 is offline   Reply With Quote
Old May 7th, 2006, 11:06 PM   #8 (permalink)
Wild Rice Chris's Avatar
Done this to three guitars with various results.
One was a 50's Kay archtop. Sounded great (if a little quiet) but the ball-end on the high E kept popping off. I gave the guitar to a friend and haven't heard of any problems (this was about two years ago).
Another was a large-body modern Gretsch. Not enough tension to move the top well, even with high-tension nylons. Sounded OK, but went back to steel.
Third was an Oscar Schmidt acoustic electric. Worked very well on this guitar, my girlfriend bought it and it's the only guitar she plays.
The nut will need recarving, and my experience was that it works best on cheap plywood guitars. What you lose wasn't there to begin with, so no harm.
Chris
http://www.ricecustomguitars.com
"The children need to learn how to build their own environment
and make their own music that is inspired by their roots."--Eugene Hütz
"All music turns out to be ethnic music."--Steve Reich
Enjoy, and please visit my homepage.
Wild Rice Chris is offline   Reply With Quote
Old May 9th, 2006, 07:35 AM   #9 (permalink)
wcap's Avatar
Or, if you have a bit of money to spare (yes, I realize this might not be the case), you could just go out and get a La Patrie classical guitar....amazingly affordable (like the Seagulls made by the same company), and very decent guitars for the money. I'm guessing this would sound lots better than nylon strings on a steel-string guitar. The LaPatries are not in the same league as, say, my Burguet, but they are very nice-playing guitars.
wcap is offline   Reply With Quote
Old May 10th, 2006, 07:06 AM   #10 (permalink)
Rob DiStefano's Avatar
Or compromise and string up with silk 'n' steel strings - the plains are steel, the wounds are classical wire over fiber.
Old May 10th, 2006, 10:50 AM   #11 (permalink)
GHS makes silk and bronze strings. Same idea, but they sound better.
Old July 2nd, 2006, 12:39 PM   #12 (permalink)
I second the silk and steel option. Martin also makes them. The basses feel similar to nylon strings. The trebels are metal. I just tried a set on my National and they give the guitar a mellower sound.
charlie cash is offline   Reply With Quote
Old July 7th, 2006, 01:38 AM   #13 (permalink)
Ice9's Avatar
I picked up an el cheapo Fender nylon string classical guitar a while back and it was around a hundred bucks.
And it actually sounds halfway decent for the price.Plays pretty nice as well.Good enough for what I do with it.The extent of my classical abilites is "Mood For A Day" by Steve Howe.
Mike
Ice9 is offline   Reply With Quote
