Old June 27th, 2011, 10:40 PM   #1 (permalink)
NGD: Ovation celebrity
I just traded an amp for a new ovation celebrity. It has a relatively low action, but I would like it to be lower. The neck appears pretty straight. The action is low at the first few frets but gets higher as you go up the neck. I don't think the truss rod needs adjusting. I think the saddle neda to be lower. Can I file it like a nut to get the action lower? More importantly, can I get a replacement if I file too much? I'm pretty ignorant of acoustics, but the action needs to be lower. Thanks for any advice.
onlybrowning is offline   Reply With Quote
Old June 27th, 2011, 10:45 PM   #2 (permalink)
magicguitar's Avatar
There are probably shims under the saddle. Remove one or two shims to get lowered action.
magicguitar is offline   Reply With Quote
Old June 28th, 2011, 08:00 AM   #3 (permalink)
Ok great! I'll check it out today and report back.
Old June 28th, 2011, 12:31 PM   #4 (permalink)
SixShooter's Avatar
Yes you can take material off the nut to lower the action. Better than a file is to use a sheet of sandpaper placed on a hard flat surface. Hold the saddle and sand the bottom of it. Take off only a small amount at a time and check it. I gotta believe you could find a replacement but you might want to check.
Why do you say that? Is that common for Ovations? Never heard of this being done.
"Something entirely new in the electric Spanish guitar field..."
SixShooter is offline   Reply With Quote
Old June 28th, 2011, 01:11 PM   #5 (permalink)
blue metalflake's Avatar
If the action seems OK at the first few frets I'd go easy on attacking the nut.
First thing to do is check the relief properly rather than just sighting along it. If that's OK, then maybe have a look at the bridge.
I've no idea about Ovations specifically, so maybe someone will be able to give more exact help
blue metalflake is offline   Reply With Quote
Old June 28th, 2011, 02:35 PM   #6 (permalink)
tap4154's Avatar
Yes, definitely check the relief before altering the nut or saddle (which probably does have shims). Sounds like a relief issue. You may already know... you access the truss by removing the round cover on the back. I have a long 3/16" allen wrench that came with mine, but you may be able to reach it with a small one. I think the Celebrity is 5 mm, and USA-made are 3/16.
tap4154 is online now   Reply With Quote
Old June 28th, 2011, 05:10 PM   #7 (permalink)
SixShooter: I say that because I had an Ovation. When I got it the action was extremely high. The instruction manual (LOL one piece of paper) mentioned that there were shims under the saddle. I removed the strings and low and behold there were three shims. I removed two of them and all was well... at least with that guitar anyway.
Old June 28th, 2011, 05:12 PM   #8 (permalink)
I have a Celeb and, yep, a shim. I removed it and it helped a lot. I them did some nut and saddle sanding to make it better.
JeradP is offline   Reply With Quote
Old June 28th, 2011, 08:36 PM   #9 (permalink)
Update: It did, in fact have shims under the saddle. There were two full shims and a piece of another in there. I took out the two whole shims and it is certainly much, much better. I put on some 11 gauge D'Addario phosphor bronze strings. It is a huge improvement.
So...now I am asking if there is a lower tension set of strings for it. I find it very difficult to go back and forth with my tele while playing with my band. I have found out the hard way that my ring finger especially is a big wuss. Until I get my calluses really built up, is there any low tension alternatives?
Old June 28th, 2011, 11:18 PM   #10 (permalink)
tap4154's Avatar
I use EB Earthwood 10-52 (plain G) on mine. In fact I use those on most of my acoustics. Plays like an electric, but still sounds/feels solid enough for an acoustic.
http://www.musiciansfriend.com/acces...strings-6-pack
Old June 28th, 2011, 11:29 PM   #11 (permalink)
Do those stay in tune very well?
Old June 28th, 2011, 11:46 PM   #12 (permalink)
SamClemons's Avatar
Put 9's on it if you want to.
SamClemons is offline   Reply With Quote
Old June 29th, 2011, 12:16 AM   #13 (permalink)
tap4154's Avatar
They stay in tune fine IMO. Of course, it's a bit of a compromise, as you'll be more stable with heavier strings and a wound G. But for me playing guitar is supposed to be fun, and these strings are much more fun to play, in the kind of style I enjoy (blues). If you're a bluegrass heavy strummer, you don't want these.
Old June 29th, 2011, 02:47 PM   #14 (permalink)
I used 10-46 on mine.
Old June 30th, 2011, 01:17 PM   #15 (permalink)
I think next time I change strings, I'll have to give them a whirl. Thanks for the tip. I have a Jasmine (Takemine's baby company) that's had electric strings and I liked it alright. I didn't know they made a set like that EB one for acoustics.
banned?
