Old November 29th, 2009, 03:46 PM   #1 (permalink)
VENDOR
Telenator's Avatar
Suggest a bracing plan
I am almost ready to begin bracing the top for what was my Guild D15M. I am building a sitka spruce top and have found that the Guild "X bracing" plan is very similar to a Martin plan. I like the sound of Martins.
So far, I have copied the Guild bracing plan from the top I removed from the guitar. The bracing is, well, "heavy duty" as compared to other styles I've been looking at.
Does anyone have any further suggestions or mild alternatives to the standard plan?
Dogs have the right idea!
www.telenator.com
Old November 29th, 2009, 05:55 PM   #2 (permalink)
If you don't have many responses here, try this place,
http://www.acousticguitarforum.com/forums/index.php
good luck
3 Chord is offline   Reply With Quote
Old November 29th, 2009, 06:11 PM   #3 (permalink)
My suggestion: start with the McRostie dreadnought plan from Stew-Mac. Just a standard Martin-style X-brace plan and a good one.
http://www.stewmac.com/shop/Books,_p...itar_Plan.html
Guilds, as most factory guitars, are pretty overbuilt. You could copy the existing pattern and do some selective shaving of the braces. After all, this is your first top and a learning process. Most builders overbuild their first, anyway. Me, I believe in starting with a tried-and-true plan. Learn by the rules first, then worry about learning how to break the rules later.
Wes McMillian
Santo, TX
westex93 is offline   Reply With Quote
Old December 12th, 2009, 12:55 PM   #4 (permalink)
zombywoof's Avatar
What I would look at - the triangle style bracing that Stu Mossman used to swear by (it is similar to what Gibson used in the mid-1950s). It is incredibly sturdy but allows alot of top flutter.
"I don't play a lot of fancy guitar. I don't want to play it. The kind of guitar I want to play is mean, mean licks." John Lee Hooker
zombywoof is offline   Reply With Quote
Old December 12th, 2009, 03:22 PM   #5 (permalink)
Tacoma was doing some interesting things with their bracing. I think the basic idea was heavier bracing on the bass side, lighter on the treble. On the other hand, what you've got may work fine with heavier strings and played hard enough to drive the top. If you google "tacoma guitar bracing" there are a number of things that will come up. For what its worth, I've got a '98 Tacoma round-hole (PM15) and compared to my Taylor dreadnought, it's a cannon.
cousinpaul is offline   Reply With Quote
Old December 12th, 2009, 04:16 PM   #6 (permalink)
VENDOR
Telenator's Avatar
Thanks guys. I ended up just copying the Guild X bracing from the original top.
This is my first effort so I didn't want to stay too far from the tried and true.
I did end up doing a little scallop work on the braces though in an effort to get a slightly more responsive top. I just now finished gluing the top to the body so, it's gonna be the way it is for a while.
There's another thread in this section with photos.
http://www.tdpri.com/forum/acoustic-...ld-photos.html
www.telenator.com
Is this the right plan? ryguy76 Finely Finished 0 April 15th, 2009 01:27 AM
I have a plan... chet Bad Dog Cafe 66 April 3rd, 2009 09:58 AM
questions about scalloped bracing: Charlie Bernstein Acoustic Heaven 2 January 15th, 2006 02:22 PM
Plan for Becoming a Telemaster Stirton Telecaster Discussion Forum 6 June 22nd, 2005 11:54 PM
New Plan out2lunch4food Telecaster Discussion Forum 19 May 11th, 2004 03:53 PM
