| Acoustic Heaven Unplugged forum for acoustic players. |
Adjusting saddle height
I have a Takamine EF341SC acoustic/electric which is in desperate need of an action adjustment. The neck is straight and the nut is at a playable height, but the action at the bridge is quite high. I took it apart to file down the bottom of the saddle piece, but it has a channel on the bottom that apparently the pickup sits in. My question is, can I file it down anyways, which would almost eliminate the channel, or is there another option that I am not seeing?
#2 (permalink) | |
I hate to be the bearer of bad tidings, but I don't think filing/sanding the saddle bottom, ESPECIALLY with a groove that the pickup has something to do with, is going to solve your action problem. |
JLS--Thank you. I initially thought I may need a neck reset too, but it seems to check out just fine with a straightedge. That is, the straightedge touches the bridge and there is no bow in the neck to speak of. I have plenty of saddle sticking above the bridge, just not sure how to go about filing it down. It should also be noted that there are no good guitar shops within an hour of me, so I would like to do it myself if possible
Buy a bone saddle blank. Save your original saddle. Try your hand at making a new saddle, its kind of easy but time consuming. If you screw up you still have the original.
Also, check out "frets.com" Good luck |
Well, I did a bit of checking around and came up with this:
http://www.takamineforum.com/forum3/...t=1727&start=0 Apparently the saddle is an integrated unit with the pickup, and cant be replaced by a regular bone saddle. I will have to check for some shims and if that doesnt work, shave the top, which doesnt sound like a ton of fun. But at least I know now. Thank you guys for all your help!!! |
| I need help with adjusting string height on Tele 3 saddle bridge | TheBlackCrayon | Telecaster Discussion Forum | 10 | March 20th, 2009 01:17 AM |
| What type of saddle height adjusting screws ? | telefunk | Tele-Tech | 16 | September 10th, 2008 06:26 AM |
| Adjusting the height of Keystones ? | viking | Just Pickups | 9 | February 27th, 2008 01:01 AM |
| Adjusting Bridge Pickup Height | maggieo | Tele-Tech | 3 | May 25th, 2006 06:42 PM |
| Adjusting Saddle Height+Truss Rod: Stupid Question | jidai | Tele-Tech | 1 | September 15th, 2004 09:44 AM |
