| Acoustic Heaven Unplugged forum for acoustic players. |
Low E Problems
Hello
I just piked up this lovely Faith Venus Cutaway guitar, left handed and basically all the string's are sounding great apart from the Low E which is catching on the fret wire and making this awful buzzing sound, it's the only problem i have with this guitar and i would recommend anyone to get one if they wanted a nice acoustic, I just wounder if anyone had idea's how i can fix this myself or will this be getting took to the local guitar tech? All the best Lewi
MIM 2008 Fender Telecaster L/H Tokai USG35 L/H Tanglewood 28ST-USA L/H Yamaha APX700 L/H Ashton VP30 1x12 All Valve Combo ProCo Rat + EHX Double Muff |
Without any other particulars, I might guess that either your action is too low or you do not have enough relief in your neck.
Try this to check relief. Capo at the first fret, hold low E string down where the neck meets the body. At about the fifth to eighth fret, you should have just enough space between the fret and the string to slide in a business card without it touching. If you cannot, or the string is actually on the fret, you do not have enough relief (bow) in your neck. Really, this measurement is done with feeler gauges and must confrom to the manufacturer's specs, but what I describe is just a quick and dirty field test to see if that is in fact the problem. While it is not hard to do this adjustment yourself, you do have to have a feel for things mechanical. Loosening your neck's truss rod, perhaps a quarter turn mightake care of the problem, but if you are not comfortable doing that then you really should have a luthier do it for you...and generally, that is not a person doing it on the counter at a music store! Alternatively, you nut may be cut too low on the low E string, and that is probably more a job for a luthier...though again, a home-brew method of Crazy-glue and bone powder is what fixed my Gibson, new out of the showroom... Best of luck; I am sure there are others here that can also give you advice. |
Bill Ashton - Thank's a lot i tried that out and there was no room at all if im honest. I've took it down to my local guitar store were the owner is a luthier and his adjusting the neck and giving it a full setup and such.
And the store i bought they guitar from want nothing to do with this problem and are trying to blame it on the gauge of the string's even though they havn't took a look at the guitar.
Well, that will hopefully get you straightened out. Certainly the gauge of string can have some to do with it, but I would think the seller would at least look at it for you...not saying much for them!
Good luck and hope you will be playing her soon. PS: Whats an Ashton amp ??? |
| PA amp problems... | photoweborama | Amp Central Station | 2 | May 5th, 2009 08:24 PM |
| new 5C5 problems | dangelico603 | Amp Central Station | 11 | June 2nd, 2008 01:32 PM |
| I have cat problems too... | Hippie | Bad Dog Cafe | 2 | February 26th, 2008 12:54 PM |
| 5E3 problems | SEK_Hakuna | Amp Central Station | 10 | January 18th, 2008 06:01 PM |
| DD-3 Problems | guit145 | The Stomp Box | 4 | January 20th, 2006 05:51 PM |
