Old October 25th, 2007, 09:44 PM   #51 (permalink)
jwells393
jwells393's Avatar
I've already cut my body. I used the template above to make a plexiglas template. I actually didn't do as I say. Somehow my template turned out to be 13 3/4 in. long. It's been a long time since I made it and I don't really remember the criteria I was using at the time. I've laid it out with a vintage style bridge and it looks like the bridge may be set back a bit toward the butt end. I measured a Mini-Strat and saw that the centerline length was 14 1/2 in.
I'll probably just use what looks right visually when determining location for the neck pickup. Since the Mini neck only has 20 frets, using a ratio based on a full sized Tele might place it too far from the neck to look right.
Here's my Mini-Tele neck alongside a Mini-Strat neck with reshaped headstock. I'll be using it for a mini-hybrid project. The maple board neck still needs frets, nut, final shaping and finish.
Here's the body with the bridge plate in the required location. It doesn't look right to me so I may start over with a larger body. I'm thinking the size of this pine scrap may have determined the length I made it.
