Originally Posted by Mark Davis
Solder a couple wires to a pre wired control plate. Screw the rest together in 30-45 mins tops. Whats so hard about that? He is buying necks off new guitars so the nut and tuners are already there. Bolt the neck to the body 4 screws 4 screws hold down the bridge add the pickups 5 screws wire it up 2 solder joints install the control panel 2 screws add the pickguard 5-8 screws. A 12 yr old can do it easily.
I give Pats guitars more credit for his photos than guitar assembly skills.
You know Mark...a Statement like yours shouldn't even require a response on my part....but I'm guessing quite a few members here, who have built the Guitars of their Dreams, using Fender, and various aftermarket parts....and performed a Set-up way beyond anything one might get from a Factory Guitar......might Strongly disagree
w/your Blanket Statement....unless perhaps you know some 12 yr. olds that have years of this kind of work, under their belt....(if they wear Belts ?)
