Old August 3rd, 2007, 12:02 PM   #11 (permalink)
toadman
toadman's Avatar
Originally Posted by tele-martini View Post
toadman,
I just replaced 12AX7 with a ECC83 and the difference is night and day. i'm going to replace the stock EL84 when I get a chance. The new pre-amp tube really brought this amp to life.
martini
my goal for the VJ is to make it distort at a much higher volume. i heard a
12AU7 was good for this. just curious what difference the ECC83 would make?
with the 80 watt combos that i normally use i set the clean channel gain so it's just starting to get gritty. then push it with either a clean boost or a od-2 pedal.
i'd also like to try and squeeze a bigger speaker in the cab. looks like a 10"would fit. and maybe even a 12 with some alteration. an extension speaker would be allright but i really like the idea of only picking up one box! call me lazy!
well the band is here to pick me up. thanks for all the responses!
toadman the plank spanker
www.slugnickel.com
www.zydecohogs.com
"The ultimate result of protecting man from folly is to fill the world with fools" Herbert Spencer
toadman is offline   Reply With Quote
