Old August 2nd, 2007, 08:43 PM   #22 (permalink)
aznrambo481
aznrambo481's Avatar
So off to home depot again today, buying saw blades. Turns out the saw originally came with the "fine" blades (out of fine, mediuim, coarse). The replacement set comes with 2 of each. Here's the difference between the fine and coarse blades:
This made a huge difference. Today I probably cut about 2 times as quickly as I did before, and felt comfortable taking out longer chunks at a time. A new record: 9.5 inches!
The following picture is a "timeline", or step-by step visual of how I shave down the sides after rough-cutting.
Starting from the right to left, you can see 3 definite sections. The first is the rough-cut, about 3-5 mm from the paper template. I start out by shaving the top part down to the paper (second section). I then gradually flatten this out till the whole portion is perpendicular to the grain, or kind of close enough...
I am of course a bit off each time, and this adds up. Some portions you can clearly see.
Check out my bands, and feel free to PM me comments on them!
The Eclectics (guitar/vocals)
SLIP (bass)
aznrambo481 is offline   Reply With Quote
