Use an old, but resharpened but to make the first pass, and move slowly, even if it results in burning” the wood.
A resharpened bit is a few thousandths smaller than a new bit. This results in the body being a few thousandths larger than desired. When you make a second pass with a new bit, it will remove the remaining wood. Since this is so very thin, the cut is generally quite smooth.
A benefit, other than a smooth cut, is the new bit will last much longer since it’s removing so very little wood.
One other thing..... make a router table... really it's the best way to do a body, and much safer.
Ron Kirn
"Life is not about waiting for the storms to pass...it's about learning how to dance in the rain."
"The Constitution only gives people the right to pursue happiness. You have to catch it yourself ." BENJAMIN FRANKLIN.
www.ronkirn.com
