Originally Posted by studio1087
Pull the baffle out of the 600.
can you fit a 10" speaker in the baffle size?
Here are the outer dimensions......
Dimensions:
Height: 11 inches (28 cm)
Width: 12 inches (31 cm)
Depth: 7.5 inches (19 cm)
12 inches wide - the cabinet wood is probably 3/4" - a 10" speaker could fit. make a whole new baffle and you could put the old baffle back in if you want to change it back.
Could it actually work? My interest is truly peaked!! That would also save me a ton of money. Thanks for the suggestion!
