Originally Posted by aznrambo481
Which means I can't do much until I get another blade at home depot, I may go tomorrow.
Make life simple and buy a coping saw. 10 tpi blades will cut through magohany pretty quick and you can cut curves. 15 tpi blades will give a smoother cut but take longer. Saw and blades should be $10 or less. It's not a band saw, but it will serve your needs better a lot better than what you are now using.
