Old July 24th, 2007, 10:37 PM   #25 (permalink)
jwells393
jwells393's Avatar
Tapping the anchor.
Threading the rod.
The anchor is screwed on to the end of the rod and secured by center-punching the rod several times
A filler strip was cut from 3/4 in walnut. After running the strip through the thickness planer to get thickness right, I hit the corners of one end with a sanding block then rounded the end by dragging sandpaper over the end.
