Old July 21st, 2007, 01:00 PM   #20 (permalink)
aussie52
Alrighty folks I've almost finished - The chassis is all wired up. I powered it on for the first time this evening and found a the B voltage to be up at 500V - not too worrying since its completely unloaded (no valves in the amp yet).
Then not long ago I plugged the speaker in and thought i'd see if everything else is OK. As soon as I turned it on I hear a hum through the speaker (every single pot was turned to zero) and a pop or two (the pops werent loud).
Obviously this is a very VERY broad problem to ask questions about.. but I have 1 lead: When I installed the output transformer the secondary polarity seems reversed to that of the original fender schematic, so I installed the secondary in "reverse" i.e. green & black wires swapped - what I assume is correct to fender schematic.
Anyways, looking at the Weber 6A20 schematic which is more or less a DR, I saw a note "If loud oscillation occurs reverse brown and blue wires" - these wires are the primary winding of the output transformer. So what I'm wondering is could it be that I have actually installed the secondary backwards?
Has anyone had this problem? I would try it out now for myself, but its after 1AM so probably time for getting sleep as opposed to playing around with 500 Volts...
aussie52 is offline   Reply With Quote
