Old July 11th, 2007, 08:31 PM   #14 (permalink)
cacibi
cacibi's Avatar
I'm sorry to be a Dumb Dudley about all this - but need some specific clarification on a few points.
Part of the problem is that my MIM 50's Esquire is wired very slightly different from most of the diagrams I'm seeing. It's wired like this.
So in that diagram I'm wondering how I would accomplish the two mods mentioned here. Both the replacing of the current caps/resistor setup with the .01 cap, and the use of the mini pot.
To accomplish the .01 cap mod - which cap do I replace and which do I eliminate? If I'm eliminated the cap that runs to ground - do I still need to ground that lug?
To accomplish the potentiometer mod (with the way my switch is wired) - I assume I just snip out the 3.3k resistor, wire the the .05 cap that's in series with that resistor to the wiper, and wire lug 3 to the switch lug that the other end of the current resistor is wired to.
Sorry if I'm making this more complicated than it needs to be - but appreciate the help.
www.krisgeren.com
cacibi is offline   Reply With Quote
