Old July 7th, 2007, 07:21 PM   #12 (permalink)
jwells393
jwells393's Avatar
Glueing in the fretboard markers. These markers were purchased from StewMac. I think they're 15/64 in. I used a super glue gel. After the glue set, I sanded them flush with the radius block and 320 paper.
Here I'm preparing to drill for the side dot markers. I'm using the level to choose a riser block for the heel to make the bass side of the neck parallel to the drill press table. I'm using 2mm plastic rod I purchased some time ago from Warmoth.
Here a picture showing the holes I drilled from the headstock into the truss rod channel. The top one is a 1/4 in hole drilled using a guide block in the jig. The second one was done more or less free hand. Both are a little off to the treble side. Looks fixable to me.
Since I have room for one more picture in this post here's a picture of neck #2 which will have the truss rod adjustment at the headstock. The channel is was routed to within about 3/4 in. of the end. A 1/2 in hole was drilled with its center about 1/2 in. from the end with the depth the same as the channel at that point.
Thanks Terry .......... but in my books, you're still The Man.
