Old July 7th, 2007, 04:35 PM   #8 (permalink)
jwells393
jwells393's Avatar
This picture shows the fret slot sawing set-up I used on neck #2. It should be understood that the StewMac fret slot miter box is intended for sawing fret slots in separate fret boards ....... not one piece necks. In normal use the fret board being sawed has parallel sides. This setup consists of a long board with the miter box attached in the center and MDF strips attached at either end level with the base of the miter box.
Here I'm sawing the slots. The neck is taped to the StewMac fret scale template. The template has notches which engage a pin in the miter box thereby making measuring unnecessary.
Slot sawing completed.
Here I'm cleaning out the nut slot with additional cuts. As you can see, if you were making a one piece Strat neck, you'd have to do some of the slots without the miter box.
Thanks guys .............. I think putting this thread together so it makes some sense might be more work than actually building the neck.
Chickenpicker .......... the MDF neck template is attached with double-stick tape.
