Old July 7th, 2007, 03:37 PM   #4 (permalink)
jwells393
jwells393's Avatar
I've got three necks underway at this time. On the two earlier necks I drilled a 1/4 in. hole into the channel using a guide block clamped to the jig. On this one I wanted a smaller hole and didn't feel like making a guide block so I drilled this 3/16 hole freehand by eyeballing that the bit was centered in the 3/8 in. hole.
Now to do the transition between the headstock and the fretboard. I'm using the Ridgid oscillating drum sander. In this photo I'm choosing a block to raise the heel so the nut line is perpendicular to the table.
Here I'm using the sander. It's easy to screw up here and sand into the headstock face so I try to stop short and do the final sanding by hand.
This shows the final sanding using the sanding drum by hand.
