Old June 30th, 2007, 02:27 PM   #7 (permalink)
chriscrob
chriscrob's Avatar
And yeah, if you have two 8 ohm, 150 watt speakers, you should be able to wire it as 4 ohm -OR- 16 ohm, but it should be capable of 300 watts either way. Someone smarter than I should be able to tell you if you can rig it to run 4 ohm or 16 ohm from a single jack plate with 2 jacks. It might be possible to do one jack and a switch.
It IS possible, but I'm not sure where you get a switch suitable for that...I would worry about using just any switch.
chriscrob is offline   Reply With Quote
