Old June 9th, 2007, 08:56 PM   #7 (permalink)
jjmantele
jjmantele's Avatar
Originally Posted by Ricky D. View Post
No way to operate that amp in the real gig world and be certain that they never exceed 25 watts output. Not by ear. If you go with a speaker rated for less power than the amp puts out, put a fast-blow fuse in line with it so you can blow a cheap fuse instead of an expensive speaker. .............
Fusing a speaker can cause an output tranny to blow. 1st the fuse blows then the open secondary makes it go poof. Unless you have a SS output, then you are fine.
JJman
If it says "Vintage" on it -it isn't.
jjmantele is offline   Reply With Quote
