Originally Posted by appar111
Removing the negative feedback loop and enriching the tone is what I'm after--- I want a full, round, warm, slightly overdriven tone at lower volumes, so I think this mod would be just what the doctor ordered. Some say it's the single most sonically distinguishable mod you can do on the amp. It would definitely put it more in the tweed camp.
I'm one in this camp for sure, and I'd do it 1st (its free and reversible, anyway - just unsolder that wire, rather than clip). Once i removed the NFB, the amp had the right 'feel', OD characteristic and warmth that I was after. I *then* chose the speaker based on the tone/attack/eq response I was after... for me the 10A125 works great. The Weber with the 'O' cone
may be on the darker side - note that's one side effect of the NFB mod, the amp gets less "stiff/glassy" and more "loose/brown".
I'll also 2nd the EQ pedal option - I've run my SIB Fatdrive (basically a tube pre with EQ, no overdrive at all), and it does open up the amp another notch.
