Plaster/Drywall and Wood also increase highs a rob your bottom. You'll find yourself doing radical things with the tone controls to no avail.
A sasd but true manifestation of today's 'home building' techniques...please note I specifically mentioned solid wood wall in my initial post...IMO plaster/wallboard walls can contribute to a sound, IF they are solid enough and filled with a substantial amount of fiberglass insulation - common studio construction techniques often suggest a 5/8th layer, then a 3/4 layer, then a 1/4 layer of drywall, with the cavity stuffed with the best insulation one can afford, with the same level of seemingly overkill on the other side of the wall.
But - chances are pretty good that most gig venues do not have more the 1/4" drywall over empty space... I know some guys who are so out-there regarding their sound they actually take a small (3 ft by 3 ft) framed and covered panel of OC 703 wrapped around a 3/4" sheet of plywood - a miniature GOBO if ou will, to place behind their amps...seen one fellow build a small 3 sided 703 GOBO and placed his amp in there...weird tactics, but very effective..
Of course this guy also mic'd his amp with a Neumann U47FET thru a rack mounted esoteric studio preamp (API)... obsessive? Yup...Worth it? He thinks so, and I'm starting to.
