Originally Posted by WireLine
Depends on the amp and (strangely) the wall...If a closed back distance from backing surafaces are less critical...if an open back, a concrete or brick wall will probably cause even the most expensive amps to sound very very bad, where as a solid wood wall (a rarity, I know) will likely cause an amp to sound better than it really is...this is one reason why recording studios cost so frakking much to build, as the walls can make or break the overall sonic signature of everything picked up by mics...
After reading this post, I moved my music room around and now have the LSS 410 sitting in front of double, solid wood doors. It's about a foot away from the doors. It sounds even better than before.
Res
