Old May 15th, 2007, 12:46 PM   #26 (permalink)
JonesKY
Originally Posted by AA4GA View Post
I've got a MIM Tele that's 4 or 5 years old. The bridge is one of the flat modern 6-saddle bridges - I just checked and it's ferrous. Any problems with the BL p'ups with this bridge?
More than likely, yes - the ferrous plate interferes with the magnetic properties of the humbucking design (for BL, Dimarzio, & Kinman designs). The result tends to be a good sounding pickup that's about as noisy as a standard single-coil. For some reason the problem tend to exhibit an increased microphonic characteristic, too. So... if you're using the pickup for tone, it may not matter; however, if you're using a stacked pup for tone AND hum cancelling AND modern, non-microphonic characteristics, then you ought to change the bridge to non-ferrous (preferable vintage style, as that affects the tone considerably, too).
Vaya con Dios,
JonesKY
6-string Double Baritone Ukelele
JonesKY is offline   Reply With Quote
