C30 and impedance...
actually there should be an external out plug on that C30. i think the O.T. tap for that one is actually 8 ohms...
i seem to remember reading a recommendation to grab an 8 ohm speaker for the C30 and run it off the external cab jack...
if you can find one, you may want to grab a Peavey Delta Blues 1X15. i've got one and that sucker moves some air - a very loud 30 watts, and fantastic with a Tele. You could then optimize your setup with the C30 tweaked just so, and the DB tweaked just so...
a used DB should be on par with the cost of a used C30...
