Old April 15th, 2007, 12:06 PM   #2 (permalink)
GuitarJonz
GuitarJonz's Avatar
Whenever I've used Fender and Duncan pups together in the past, (usually Fender OV in neck, with Duncan in bridge, like your setup), I set the Duncan bridge up normally, with white to switch and black to ground. Then I reverse the leads on the neck pup: black to switch and white to ground, this has always worked for me, probably at least 5 different times over the years.
