Originally Posted by SinnerBoy61
what's the procedure for checking at the jack?
Just plug a guitar cable into your guitars jack use the probes of your ohm meter to contact the other end of the cables plugs' tip and outside sleeve (ring) which is the ground. The equation above still holds true for the pots which are still in parallel with the pickups. Of course if you have an Esquire...one position is pure pickup so the pots would be out of the circuit.
