Measure the output of the switch with respect to ground (the ungrounded outside tab on the volume pot. The reading you get will be a little less than the actual resistance of the pickup. The pickup and the volume pot are in parallel. The equivalent resistance is determined as follows:
As an example assuming the actual resistance of your pickup was 6 K ohms and the pots are 250K............ (6x250)/256=5.86 K ohms
