Old October 31st, 2003, 11:08 PM   #3 (permalink)
Kevin
Kevin's Avatar
Did you reverse-wire the pup for some reason? Sounds like you've got the ground wire run to hot and vice-versa. Sometimes you have to do that because of phasing problems with your other pup. If so, you need to switch the cover's ground wire to the other eyelet, as right now it is run to hot.
