Old October 29th, 2003, 07:05 PM   #7 (permalink)
Wally
Brian, that is even more reason to go spend a few bucks for a circuit tester. A GFI outlet that is miswired is not only a problem, but it may not function as needed when things go wrong. A tester will tell you if you have an open ground, open neutral, open hot, hot/grd reversed, hot/neutral reverse, or correct wiring. For less than $10 you get a great tool.
