Old October 15th, 2003, 07:39 PM   #6 (permalink)
hippietim
hippietim's Avatar
Re: Loose ground!
Originally Posted by Andy B
Brass is a good conductor. What you are describing sounds like a grounding problem. You can ground the bridge plate with a bare wire lying under it fed through the wiring channel & soldered to either pot.
I don't think so. Touching the bridge plate anywhere works fine - just not touching say a single saddle.
hippietim is offline   Reply With Quote
